Server Version#: 1.24.3.5033
Player Version#: web
Every night, Plex’s memory usage starts taking off around 19:00 until it is OOM killed:
The orange line is Plex. The bottom graph is cache.
Plex reports it is updating metadata for City of God the whole time:
I deleted that specific movie a few nights ago but it didn’t stop this from happening.
Around this time, the logs look like this:
Sqlite3: Sleeping for 200ms to retry busy DB.
Sqlite3: Sleeping for 200ms to retry busy DBlibc++abi: terminating with uncaught exception of type soci::soci_error: sqlite3_statement_backend::loadOne: database is locked
****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.24.3.5033-757abe6b4/PLEX MEDIA SERVER/6b0ab279-f3ff-426c-0436d4a7-90f7bb36.dmp
There are a LOT of sleeping for 200ms lines.
Here’s that crash report and the logs since the last time this happened about 24 hours ago
crash.zip (5.4 MB)
plex.log (6.1 MB)
It happily comes back up after being killed, but when this was first happening I hadn’t set a memory limit and it was consuming memory until the kernel OOM killer started slaughtering processes and bringing the machine down.
Still happening daily at 19:00.
Plex also occasionally becomes unresponsive during the day and needs to be restarted, the logs are full of that same Sleeping for 200ms error.
There needs to be a way to actually report bugs, this process of posting to the forum and being ignored sucks.
Got an OOM warning from plex today as well (same version and running in docker). I do have a RAM limit set, it consumed 6GB before it was killed. It came back up this morning and subsequently crashed not long after.
1.24.3.5033-757abe6b4.zip (758 Bytes)
EDIT: lol apparently it crashed but didn’t even produce the dump it claimed…the crash folder is there but it is completely empty…
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User uid: 99
User gid: 100
[cont-init.d] 10-adduser: exited 0.
[cont-init.d] 40-chown-files: executing...
[cont-init.d] 40-chown-files: exited 0.
[cont-init.d] 45-plex-claim: executing...
[cont-init.d] 45-plex-claim: exited 0.
[cont-init.d] 50-gid-video: executing...
[cont-init.d] 50-gid-video: exited 0.
[cont-init.d] 60-plex-update: executing...
No update required
[cont-init.d] 60-plex-update: exited 0.
[cont-init.d] 90-custom-folders: executing...
[cont-init.d] 90-custom-folders: exited 0.
[cont-init.d] 99-custom-scripts: executing...
[custom-init] no custom files found exiting...
[cont-init.d] 99-custom-scripts: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting Plex Media Server.
Critical: libusb_init failed
****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.24.3.5033-757abe6b4/PLEX MEDIA SERVER/db2a330f-d26a-4c00-a0d3f48b-4b63b672.dmp
EDIT2: Well here are the last 24 hours or so of server logs at least since the crash dump wasn’t created… ServerLogs.zip (28.9 KB)
Seeing the same thing. Mine started ~16:35 local time (2235GMT) which I don’t have anything else scheduled.
Still happening in 1.24.4.5081
Optimizing the database and cleaning bundles didn’t affect it either.
I believe I’m getting memory issues on my Windows based server as well - Plex Media Server version 1.24.4.5081 on Windows 10 Professional
I can’t be 100% sure as I don’t have memory monitoring on my Windows machine however looking in the logs there are 100s of mentions of the below around 5 minutes into my scheduled maintenance window (2am till 5am)
Oct 01, 2021 02:05:41.452 [8044] ERROR - Format [JPEG] - DIB allocation failed, maybe caused by an invalid image size or by a lack of memory
Keeps causing crashes overnight, and it doesn’t come back itself (I have to log on to the server and restart it manually). It’s infuriating, it appears to only have started in the last week or two.
My music sonic analysis also refuses to work which is annoying - I’d really like to use it… but I think as the scheduled jobs are crashing my server it’s never getting a chance to do the analysis.
In the meantime I will change my scheduled maintenance window to be earlier and see if I see memory usage shoot up.
Still happening. @elan know anyone who could take a look at this?
My Windows install is also having the same issue and crashes every single night and must be manually restarted. I have 1.24.4.5081 installed.
It’s really a bummer that PMS is 32 bit. I have plenty of RAM! But I suppose it’s easier just to make one app that works for everyone rather than 2.
I have disabled the refreshing metadata option and seems to have bypassed the crashing. Hopefully this gets fixed soon. Thank you!
Edit: as a side note, I have noticed a handful of crashes outside of scheduled tasks when trying to do memory intensive tasks so makes sense. Need to fix memory handling.
I had an issue of crashing every 3 days due to a memory issue. I disabled refresh metadata every 3 days and that fix the issue for a little while.
Now crashing every night. I have no idea what it could be now. @sa2000
I am now on latest beta
Has anyone downgraded to a stable version that doesn’t crash every night? I am slowly going backwards but haven’t found one yet.
Not sure where else to look at this point. The server is crashing every night and sometimes during the day. I have tried downgrading to several older versions and it hasn’t helped. I also went through the process of dumping and recreating the com.plexapp.plugins.library.db DB. The only error I see in the “Plex Media Server.log” is
Oct 12, 2021 03:28:27.119 [12604] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: out of memory
and
Oct 12, 2021 03:28:29.707 [15744] ERROR - SQLITE3:0x1cb238d4, 7, failed to allocate 85120 bytes of memory.
These sure sound like memory leaks as the windows server running plex has 48G of memory allocated to it.
I looked through the logs and don’t really see anything else significant.
I will gather logs and open a new thread after the next crash since this post was originally for Plex installed in docker which mine is not. Standard windows install.
Hey I’m not sure if my issue is related but I had an issue where plex was getting stuck scanning the tmp folder every night and eating up system ram because the tmp folder had 5.6 million folders in it and the scan process was taking forever.
Wouldn’t hurt to have a look.
Server Version#:1.24.0.4930
TrueNAS-12.0-U5.1
Plex jail: 12.2-RELEASE-p9
Hello, anyone run into this issue where the ‘/iocage/jails/plexmediaserver/root/tmp’ folder is full of empty pms-xxxxx-xxxxxx-xxxx folders? In my case there were over 5.6 million folders in there. Not sure how long it took to create all the folders but from what I could see it’s been going on since January 2021. It’s very difficult to work with a folder that big so I could not get a complete folder li…
PMS is a 32bit application so is limited to 2gb ram. Definitely memory issues on my end too
itsnotv
October 22, 2021, 9:09pm
15
I have been experiencing similar issues with 1.24.3.5033 on docker.
It is definitely not from a scheduled job. It happens when I try a play a video, Plex starts maxing out the CPU and the UI becomes unresponsive. The RAM usage increases from <500 MB to >3 GB. The IOPS are very high >4000. I cannot reproduce this with the same file. It occurs randomly several times a day. There is definitely a major bug here. I turned on verbose logs, I didn’t find any errors but I did see this messages repeated several times when plex was unresponsive.
Oct 22, 2021 12:22:54.363 [0x7f9ffc06cb38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Oct 22, 2021 12:22:54.363 [0x7f9ffc06cb38] DEBUG - Selecting best audio stream for part ID 73133 (autoselect: 0 language: en)
Oct 22, 2021 12:22:54.363 [0x7fa01688ab38] DEBUG - We're going to try to auto-select an audio stream for account 1.
After being unresponsive for >10 mins it generally recovers on its own.
For anyone experiencing this I was able to get it to stop by deleting my Plex database and starting over.
Disappointing that Plex is releasing updates seemingly incompatible with older versions of the database, even more disappointing nobody is willing to respond when bugs are reported. I report bugs and provide logs for free, for software I paid for, to help out the developers and not only do they never fix anything they deliberately ignore you.
I continue to regret ever paying for Plex Pass. Shocking that a software company thinks this is an acceptable way to operate.
Same problem here, and it crashes TruNAS -
Dec 10 08:15:45 MAGPIESNAS kernel: vnet0.5: promiscuous mode enabled
Dec 10 08:15:45 MAGPIESNAS kernel: lo0: link state changed to UP
AGPIESNAS swap_pager_getswapspace(16): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(12): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(9): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(32): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(28): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(25): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(22): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(17): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(13): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(10): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(8): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(6): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(20): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(18): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(14): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(11): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(5): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(7): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(4): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(3): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(3)[969]: Last message 'failed' repeated 1 times, suppressed by syslog-ng on MAGPIESNAS.local
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(21): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(19): failed
Dec 10 04:13:43 MAGPIESNAS swap_pager_getswapspace(2): failed
Dec 10 04:13:43 MAGPIESNAS kernel: pid 46237 (Plex Script Host), jid 4, uid 972, was killed: out of swap space
Dec 10 04:13:43 MAGPIESNAS kernel[969]: Last message 'pid 46237 (Plex Scri' repeated 1 times, suppressed by syslog-ng on MAGPIESNAS.local
Dec 10 04:13:43 MAGPIESNAS kernel: pid 88539 (Plex Script Host), jid 4, uid 972, was killed: out of swap space
Dec 10 04:13:43 MAGPIESNAS kernel[969]: Last message 'pid 88539 (Plex Scri' repeated 1 times, suppressed by syslog-ng on MAGPIESNAS.local
Dec 10 04:13:43 MAGPIESNAS kernel: pid 326 (python3.9), jid 0, uid 0, was killed: out of swap space
Dec 10 04:13:43 MAGPIESNAS kernel[969]: Last message 'pid 326 (python3.9),' repeated 1 times, suppressed by syslog-ng on MAGPIESNAS.local
Dec 10 04:13:43 MAGPIESNAS kernel: pid 88545 (Plex Script Host), jid 4, uid 972, was killed: out of swap space
Dec 10 04:13:43 MAGPIESNAS kernel[969]: Last message 'pid 88545 (Plex Scri' repeated 1 times, suppressed by syslog-ng on MAGPIESNAS.local
Dec 10 04:13:43 MAGPIESNAS kernel: pid 46260 (Plex DLNA Server), jid 4, uid 972, was killed: out of swap space
Dec 10 04:13:43 MAGPIESNAS kernel[969]: Last message 'pid 46260 (Plex DLNA' repeated 1 times, suppressed by syslog-ng on MAGPIESNAS.local
Dec 10 04:13:43 MAGPIESNAS 1 2021-12-10T04:13:43.813008+00:00 MAGPIESNAS.local upsmon 1197 - - Poll UPS [CP1500EPFCLCD@localhost:3493] failed - Server disconnected
system
Closed
March 10, 2022, 10:12am
18
