Hi Plexamp team,
I would like to suggest a new feature: the ability to easily merge two or more existing playlists into a single one.
My Use Case: I currently manage a large library with over 200 playlists. Many of these are short, 30 to 40-minute specific mixes (for example, “Pop/Rock 1”, “Pop/Rock 2”, etc.).
Frequently, I want to combine these smaller playlists to create a massive “radio-style” master playlist for longer listening sessions. Doing this manually track-by-track is very time-consuming.
Proposed Solution: Add a “Merge” or “Combine” option in the playlist context menu. When selected, it would allow the user to pick another playlist to append the tracks to, or create a brand new playlist containing the combined tracks of the selected ones.
This would be a massive quality-of-life improvement for power users with extensive playlist collections. Thanks for your great work on the app!
