I’ve created 2 lists with about 1000 songs, I’d like top create a third one which would be a merge of the two.
Is it possible to do it easily ?
I can’t even select all the element of a list at once, and if I do it one by one I don’t have the option to add them in a new list.
I guess you’re talking about merging 2 playlists?!
While you can actually select all items (hover over the first item and select it, scroll to the end of the list, press Shift and select the last item)… it’s true you cannot merge playlists. In fact, all you can do with those multi-selected items in a regular playlist is to remove them from that playlist.
When doing it one-by-one you can hover over each single item and click on Add to Playlist from the context menu of that playlist item (via ...).
Edit: not sure if you can achieve that with something like the ExportTools plugin
