I’ve noticed that when I merge albums in Plex Music, it seems to trigger Sonic Analysis and a rescan of the entire album. I record 2-hour radio shows weekly, and to keep the Recently Added section clean and organized, I merge each new episode into an existing album (which already contains around 400 episodes, each 2 hours long).
The problem is, once I add a new episode to the album, Sonic Analysis starts running again for the entire album, re-analyzing hours and hours of content that has already been scanned before. This process takes quite a while.
Is there a way to avoid this behavior, or is this just how Plex handles merged albums? Any tips or insights would be greatly appreciated!
You could just turn off sonic analysis for this particular library as it doesn’t really make sense (to me at least!) to look for sonic similarities of a 2-hour radio show
Edit: forgot to answer the actual question…
Sonic Analysis will run again if a new track is added to an album as this could have an impact on the sonic similarities of the album as a whole.
To avoid this happening long-form audio formats are probably best off in a separate library from regular music tracks. This way sonic analysis can be switched on or off per library.
You can have multiple libraries in Plex, and for long-form audio there is an advanced option to ‘store track progress’ so it resumes playback rather than starting from the beginning. Plexamp also has a setting that changes the playback controls for long-form audio.
