Metadata Agent for XML generated with ThumbGen
For all the people having a library generated with ThumbGen here's a way to use the xml-information stored by thumbgen in an .nfo file  as Metadata in Plex.
This agent  scans for all .nfo files in the same folder as the movie and trying to extract the meta data for it.
Sample ThumbGen MetaData .nfo:
<?xml version="1.0" encoding="utf-8"?>
  false
  Herr der Ringe: Die Gefährten, Der
  Lord of the Rings: The Fellowship of the Ring, The
  2001
  In grauer Vorzeit schmiedete der dunkle Herrscher Sauron Ringe der Macht und dabei auch den Einen, den Meisterring, der über alle anderen Ringe Macht hat...
  Herr der Ringe Die Gefährten, Der (Lord of the Rings The Fellowship of the Ring, The) (German).mkv
  Power can be held in the smallest of things...
  8.8
  tt0120737
  10.12.2001
  Rated PG-13 for epic battle sequences and some scary images
    Cate Blanchett
    Orlando Bloom
    Billy Boyd
    Marton Csokas
    Megan Edwards
    Abenteuer
    Action
    Fantasy
    Peter Jackson
  178
  FSK 12
    New Line Cinema
    WingNut Films
    The Saul Zaentz Company
    Neuseeland
    USA
    http://cf1.imgobject.com/posters/8b8/4cc48d685e73d677850018b8/the-lord-of-the-rings-the-fellowship-of-the-ring-original.jpg
    http://cf1.imgobject.com/posters/3bd/4c438e267b9aa145950003bd/the-lord-of-the-rings-the-fellowship-of-the-ring-original.jpg
    http://www.ofdb.de/images/film/5/5462.jpg
    http://cf1.imgobject.com/backdrops/e44/4bc90386017a3c57fe000e44/the-lord-of-the-rings-the-fellowship-of-the-ring-original.jpg
    http://cf1.imgobject.com/backdrops/219/4d7333c45e73d6777c000219/the-lord-of-the-rings-the-fellowship-of-the-ring-original.jpg
      Resolution_720p
    720P
      Format_MKV
    MKV
      Video_H264
    avc
      Audio_DTS
    DTS51
      Subtitles_Generic
    Subtitles
    23.976
    2.42:1
    1280x528
    AVC
    4 Mbps
    DTS
    7 / 6
    2 Mbps
    13698
    228
    3h 48m
    9391409122
    8,75 GB
    Matroska
    German
    de
    German
    de
      UTF-8
      Deutsch
      German
For questions, bugs, enhancements... I'm sure you'll find me ;)
ThumbGen .nfo MetaAgent: https://www.dropbox.com/s/ube08dcn8iad3yq/Thumbgen_.nfo_Importer.bundle.7z
Mirror: http://www.share-online.biz/dl/F6ZVFHVMUU5I
Greets
CCarpo
This look interesting but I have some questions:
1. Does the nfo file need to be named a specific way (matching the movie file name or anything will do like movie.nfo for instance)
2. There doesn't seem to be any setting for Collection though with a film like the one you are using as exemple, having it set directly in The Lord of the Rings collection would be handy
3. Are you planning to develop or show us an example (if it already works) on how to add a series and the episodes from that series?
4. I guess all the fields don't have to be filled and that the agent will only take what is registered in the file, Plex doing its work to fill for the rest (like for the part which I think is redundant)
5. The pictures only link to internet, is it possible to link to pictures already in the folder or can we let that part empty and have the local info agent take them?
Hey,
Thanks for your agent, it works great!
I installed in on my PC and it's perfect but on my mac, I can't seem to get it to work. I unzip it to the plug in directory and restarted the computer but can't seem to be seeing it in my setting. Is there anything else I should do?
show up fine for me i did not even have to restart computer or server
Hi guys,
sorry I lost track of this post.
To answer your questions:
1. It just have to have the .nfo extension. And there should be only one nfo per folder.
2. Collections are not part of ThumbGen Info file afaik and so is not supported. I did group my movies manually in the collection
3. I never used ThumbGen for Shows (TVRename + Plex was enough for my needs) so probably not.
4. I'm not quite sure about this. This depends if Plex uses only one Agent (in this case mine) or can use multiple agents
5. The pics could also link to local resources, you also can configure ThumbGen not to fill this section. My background e.g. are local resources and shown in Plex without nay problems.
@itamarj: Sorry no User Apple here. It should work as well as the Plex Plugin Architecture is relatively robust.
