Metadata and poster/background image no longer working correctly
Server Version#:1.18.4.2171
Player Version#:4.12.3
This stopped working after the last update. I then did a manual install on the latest version today in hopes of fixing the problem. Some show blanks some show as movie screen shots. Fix Match does not seem to work when you do select the correct match it doesn’t import any of the metadata. This become a tedious task with over 600 movies. I have tried some of the fixes suggested by ChuckPA related to deleting HTTPCookies.
Downgrading to version 1.18.2.2041 fixed the problems I was having
