I have several dozen TV shows that, after adding, only have partial descriptions. An example is Drew Carey, S1E2:
“The best candidate for an available position at the store is an attractive female whom Drew likes,”
Anyone else seeing this and aware of a workaround? I’ve tried fixing it manually, but it goes back to half sentences when the library is automatically refreshed.
Since this description doesn’t appear either on TheTVDB nor on TheMovieDatabase,
I think embedded meta data in your files are to blame.
Do this:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
Then ‘Refresh Metadata’ on this show,
then wait a few minutes.
