Metadata is not being retrieved from the TVDB
I have Dragon Ball Z season 1 and Dragon Ball Z season 2 ripped and placed into a section. I have the 6 disc season for each so they are 6 .m4v files in each season. Season 1 has the metadata retrieved for each episode, but season 2 does not. Anybody else run into this issue? help would be appreciated.
How do you have the actual files named?
I have the files name “Dragon Ball Z S02e40-e45” etc. i double checked the files to make sure they were accurate. would it be better to name it s02e01-05? you know as in episode 1 through 5 of the second season?
They should be named identically to how they are listed on thetvdb.com - the last episode in season 2 looks to be E35 so having them called E40+ is why it can't find them. If episode 1 through 5 is what you have then yes, they should be called E01 to E05.
