The Plex scanner is the recommended modern version which does not appear to be utilising the same source data as either TMDB or TVDB. All four episodes and the TV Show itself are all affected within the Plex Media Server.
Some of the metadata appears to be fine. For example the TMDB score is correct and the TV Show’s description is correct, but everything is incorrect.
Over at tmdb I’ve also added episode level external ids from tmdb → tvdb. Changes will take between 48/72 hours to replicate to plex so hopefully between that and the plex metadata team it’ll sort it out.
