Every time there is an update and I select it, I have about a dozen movies that the metadata changes. So each time I go in an select fix match. Is there a way to stop this from happening? It is really annoying.
Hello anyone… Plex personal do you follow this forum?
Thank you for the reply I will give that a try.
The last Plex update and all is well, it worked thank you.
