Metadata preservation before fresh install
I just wanted to double check the steps I need to take before reinstalling Windows 11 in order to save my metadata and work I’ve done with collection within Plex.
  1. All I need is to find is the Plex Media Server folder in the app data folder on my C: drive and copy the whole folder… Correct?
  2. When I have reinstalled Win 11 and then Plex I just copy the backup folder into the Plex Media Sever folder created during the install… Correct?
  3. I will attempt to make sure Plex is up to date before I back the folder up. I wondered though if from backing up the folder that plex was updated, would copying the backup folder from an older version cause issues?
  4. Are there any steps I’m missing?
  5. Does the folder I mentioned above essentially store all artwork, tv tunes, metadata etc?
Best use this as your reference.
https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
Thank you for the link :grinning_face:
If you have more than one hard drive storing your media, better note down which drive is currently assigned to which drive letter.
Then after the fresh Windows installation, restore those drive letters to be the exact same as before.
This ensures that Plex can find all media where they are noted to be in its internal database.
Following the guide it mentions closing down the plex server is that adequate or do I also need to clear the plex update service as well that is running
There’s no need to care about the update service.
