Server Version#: 1.13.5.5332 (Nvidia Shield)
Player Version#: 3.73.1 (Web)
Really struggling with getting ratings into my library. The standard percentages that show up are pretty useless as per the post about The Movie Database not being a good source for ratings
I changed my agent to use Rotten Tomatoes for ratings however there’s no easy way to update movies. The only thing that seems to work is opening a movie, selecting Fix Match and then selecting Auto Match using Plex Movie. Even then it’s hit and miss if it brings back the right info
The following have no effect
- Refresh Metadata at a film level
- Refresh All Metadata at a library level
- Fix Match and then select the right film
I can’t believe that I have to open each movie individually, select Fix Match then pick Auto Match > Plex Movie in order to update the ratings, surely there’s an efficient way to do this? I never had any problems with Kodi or other platforms in simply updating a library
I’m running my server on an nvidia shield so options to move files around, etc are very limited. I’ve also got a backup running on my main desktop PC but it has the same issues. Any help appreciated
Thanks !
