Server Version#: Latest
Player Version#: Latest
I have 5 movies in the library that don’t have imdb ratings:
What can be the issue?
xml.zip (13.4 KB)
xml.zip (13.4 KB)
Here are the logs of the match
Plex Media Server Logs_2019-09-23_17-40-14.zip (1.3 MB)
Can’t be fixed. Only Plex can update/add the movie ratings correctly:
Edit:
Obviously this CAN be fixed. But only by Plex updating their meta.plex.tv server, as this is where the ratings come from. No need for endless debugging your setup guys!
Also, RottenTomatoes ratings share the same issue, in case anyone are considering changing to that, to solve the issue. So, not a workaround.
And, plugin support is no longer. In case anyone considered something like the excellent OMDB plugin as a workaround:
