Metadata wont update
Have a cloud server that’s been pretty much perfect for months. Media is mounted via RAI drive which I tried switching my login credentials to my second account (same path to media) and realized it still started un-syncing my media. I quick stopped and logged back in with the original name.
1500 of my movies had to be re-scanned which it did successfully, but it’s not re-grabbing about half of the cover arts/description/etc. I’ve tried restarting server, tried clicking “refresh metadata” (which works on some, but not a lot), re-scanned / optimized / emptied trash, etc. I’m not sure if maybe it’s an API limit for the day with Gsuite or something, but is there anything else I can try? Even doing “Fix Match” and selecting the 100% likely file, some aren’t even updating
Agent List: https://imgur.com/l6TKD3S
Did nothing different but repeated reboots and metadata refreshes, and while it hasn’t for sure corrected them, it seems to be gaining progress. Maybe it was an API limit issue with cloud. Feel free to delete.
