Host OS#: Ubuntu 20.04
Docker Version#: 20.10.4
Server Version#: 1.23.4.4805
Docker-compose:
#PLEX Media Server
plex:
image: Package plex · GitHub
container_name: “plex”
network_mode: host
ports:
- 32400:32400
volumes:
- ${USERDIR}/docker/plex:/config
- /nfs/media/Movies:/movies
- /nfs/media/tv:/tv
- /nfs/media/Anime:/anime
- /nfs/media/Music:/music
environment:
- PUID=${PUID}
- PGID=${PGID}
- VERSION=public
- TZ=${TZ}
restart: unless-stopped
Attempting to migrate the view-state from the old server to the new server running in docker, no errors following the support article at move view state. The container, or at least the Plex media server service running on it quickly climbs in CPU utilization until it becomes unresponsive and any remote or local connection times out until the container is restarted.
Jul 16, 2021 20:54:15.115 [0x7fe599c29b38] Debug — Content-Length is -1 (of total: -1).
Jul 16, 2021 20:54:15.655 [0x7fe59b115b38] Warning — SLOW QUERY: It took 25500.000000 ms to retrieve 50 items.
Jul 16, 2021 20:54:19.859 [0x7fe59b115b38] Warning — SLOW QUERY: It took 31030.000000 ms to retrieve 50 items.
Jul 16, 2021 20:54:26.029 [0x7fe59f5f7b38] Debug — Completed: [x.x.x.x:56619] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (28 live) TLS GZIP 20014ms 5 bytes (pipelined: 12)
Jul 16, 2021 20:54:26.132 [0x7fe59f61ab38] Debug — Auth: authenticated user 1 as xxxxxxxxxxxx
Jul 16, 2021 20:54:26.151 [0x7fe59e885b38] Debug — Request: [x.x.x.xx:56619 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (28 live) TLS GZIP Signed-in Token (xxxxxxxxxxxx)
Jul 16, 2021 20:54:26.151 [0x7fe59e885b38] Debug — Content-Length is -1 (of total: -1).
Jul 16, 2021 20:54:28.609 [0x7fe59f5f7b38] Debug — Auth: authenticated user 1 as xxxxxxxxxxxx
Jul 16, 2021 20:54:28.609 [0x7fe59e885b38] Debug — Request: [x.x.x.x:42392 (WAN)] GET /library/recentlyAdded (29 live) Signed-in Token (xxxxxxxxxxxx)
Jul 16, 2021 20:54:28.853 [0x7fe59f5f7b38] Warning — [CERT] TLS connection came in with unrecognized plex.direct SNI name '72-193-220-25.aaa2cb85a08d4233af4bae04d37ed0c2.plex.direct'; using installed plex.direct cert
Jul 16, 2021 20:54:28.862 [0x7fe59f61ab38] Debug — CERT: incomplete TLS handshake: sslv3 alert certificate unknown
I believe the SLOW QUERY logs are eventually locking the system up and it cannot respond to TLS or any other requests for the server. Is this a process that I just need to let run, or can I force the running QUERY list to abort. Only 1 of the Libraries has had the view state synced over.
Should I stop the media server service, cancel the table merge, and restart the table merge and leave the media server service not running for an extended time? I would expect to see COLUMN LOCKED or something to that effect if it was because the media server was running while the writing to the view state table was occuring.
