Server Version#: DSM 7.0.1-42218 update 7
Player Version#: 1.110.0.351-4e48eb83
For purely narcissistic reasons, I’d like to create a guest account to my music server that reflects all the ratings and playlists that I’ve put together on my admin account. Is there a way all my friends can get the benefits of my good taste without having to be in my admin account?
If they are at your home you could create a managed users (let’s call it “music mlibrik” for now) and use this account to rate the songs.
Or you could try to create a smart playlist and share this playlist with “music mlibrik” Then let your guest access your guest account and your music library.
I’m not sure if a shared user sees your ratings but IIRC he doesn’t ![]()
If you have an old iPad or iPhone you could us PlexAmp. Log in with your admin account and switch to the guest user (in this case I would recommend to protect your admin account with a PIN). Your guest could connect some BT speakers/headphones to the device or stream it to Sonos or an AirPlay or Cast compatible device in the same subnet.
Hope this helps!
