seems last update for either the app or server has created a bug for me on Android TV( 2017 Shield) as we have lost the “Recent Playlist” from the plex home screen, i went back in to the hub settings on the side bar for our TV shows and for our Movies and added them back, oddly it creates 2 separate “Recent Playlist” compared to before it was just all in one. but once i exit the app, it looses them again from the plex home screen.
Been having a similar issue, I can only get Recent Playlists to appear on the Home screen when it’s being Auto managed, as soon as I go to manual and start removing the online stuff and duplicated playlists of my Movies and TV sections, the Recent Playlists will vanish after hitting Done.
Still doesn’t work for us either on Android under manual, it does work normally on the Roku thou, one line with both TV Shows and Movies Recent playlist. not sure if it is a bug or by design, plex for kodi is still under the old user interface (not Uno), so not able to compare it.
Thought I had it working on my Android (Desktop is lacking the option altogether) when when I refresh the app the Recent Playlists will appear for half a second before it removes itself again.
EDIT: Immediately after posting that, I reset the customization again on the PC and it let me add it, it also appears to only stay on the PC, phone still not seeing it.
