There is a copy of parasite in my plex movie folder but its not appearing in plex. i did have another copy which i deleted as the subs were bad. any idea why the new copy isnt showing in plex? i also noticed my movies folder has 896 movies but plex is only showing 872
ive optimize the database and cleaned the bundles and searched for new file and also metadata
Look at trying the Plex Dance.
that seemed to work for parasite but there still 24 movies now showing up. any way to figure out which ones are missing?
I would suggest checking off movies in one window/Plex posters to a window containing your collection Directory
Thanks, parsite movie that i moved back into to my movies folder doesnt seem to be getting any metadata. might that be the reason it wasnt showing up before or link to not getting metadata some how?
I also created a new test movie folder in plex and put the movie in it and it also not getting metadata. the folder is named parasite (2019) and file is also
Forward how you have it named please.
Parasite (2019)
Parasite 2019.mkv
Ok can you take screenshots how your agents are ranked in Plex media server.
Also ~ Parasite (2019).mkv
Enable Local assets and I like Movie database for Plex movie. Click on the cog to the right.
With Plex Movie Enable all
Restart Plex and refresh your metadata of that file from the poster ellipsis
Cheers, glad to hear it
thanks for your help. so the only way to find the missing 24 movies is to cross reference my plex movies and my movies download folder?
the latest star wars is behaving the same
putting in the () on the year seems to let plex see it. my of my movies dont seem to have () in the year and plex sees them alright
So your all sorted now?
Have you tried match from Vertical ellipsis on the bottom right of Posters in the Server’s Browser window.
