Server Version#: 1.29.1.6241
Player Version#: 1.55.0.3278
I’ve been adding some movies lately and have found 2 that are in the proper folder but do not get recognized by Plex. One does show up under other ways to watch, and the other doesn’t appear at all. They do match the name & (date) in themoviedb. What else can I look for to figure this out?
What are the titles you’re having trouble with?
Have you looked to see if those movies have been matched as a duplicate with another movie you already had in your library?
(Top left of the library)
Other ways to watch is probably showing you a copy on another service who has the movie available to stream, not your copy
Can you post your server logs? Might be a permissions issue or something else we can spot.
Some things to try:
Sort the library by date added, so the most recently added movies appear first. That can help if the movie is being incorrectly recognized and added under a different name.
The file is an MP4. If Plex is configured to use local metadata and that metadata is incorrect, it can throw off Plex’s ability to correctly match movies.
Use Subler to verify and, if needed, modify any embedded metadata.
Unless needed, disable reading of embedded metadata.
If using thePlex Movieagent/scanner:
Edit the library
Choose Advanced
Deselect Prefer local metadata
Save Changes & refresh the library metadata. -
Add the TMDB ID to the file name.
Then Plex Dance the movie.
A Matter of Life and Death (1946) {tmdb-28162}.mp4
Good catch.
Looks like the movie has been renamed.
IMDB has it as Stairway to Heaven, and immediately underneath it says “Original title: A Matter of Life and Death.”
SOLVED THANKS TO ALL. It seems that A Matter of Life and Death is the British name, and Stairway to Heaven is the US Name.
