Server Version#: 1.15
Player Version#: 2.27
These are on Mac
I just noticed that in this latest version playlists are no longer available under videos. Reverting back to 2.25 with the same server returns the playlists. Have they just been moved?
These are on Mac
An update, I just installed the new server 1.15.1.707 and the new player 2.28 and there is still no playlist available in the video section. Personally I use this to play music videos, I have built a library of videos can select a playlist and hit shuffle. This has worked thru version 2.25 but not the player builds since. Would be nice to get this ability back.
This is a bug in PMP and is has already been reported.
AFAIK it only affects ‘Other Videos’-type libraries.
You are correct I do not see it in other libraries, thanks for the reply.
