The add to playlist seems to not be working now
Server Version#:
1.20.4.3517-ab5e1197c
I’m selecting files from my other folder and when I use the add to playlist to add the selected files it no longer works. This started happening before the last update. If I do a smartlist it works, if I click on the single video in my other folders I can add that to any of the playlists. Anyone else seeing this?
I have the same issue. I started seeing that yesterday, but that was the first time I tried it since updating the the latest media server.
Ditto here - can’t add to or create playlists (always just creates an empty playlist without any entries). Something changed in the past few days…
Plex Media Server 1.20.4.3517-ab5e1197c
Do either of you now have it working after the last update. Still broken for me. Makes making playlists painful.
Negative - I completely uninstalled (wiped appropriate AppData & Program Files folders as well manually) and downgraded to 1.18.9.2578-513b381af. Not sure if it’s a client issue or server at this point but haven’t done much debugging to see where the issue is (beyond looking at the logs anyway).
After I just installed the latest server update (Version 1.21.0.3616), this issue has been fixed.
Tried it - seemed to work to just add a single video to a new playlist, but subsequent attempts are still failing (and I wasn’t able to re-create the first one that worked).
Odd - wish I knew what the root cause was…
Must have been a client issue as when I just updated to version 1.24.0.1483-714cba36, playlists are now working again (albeit with an older server version 1.18.9.2578-513b381af; really not interested in messing around with a newer server variant now that it’s working again).
