Missing the Install Channels option on https://plex.tv/web portal
Complete beginner so please excuse my ignorance.
I have logged on to https://plex.tv/web, and configured Movie flibrary etc, and have the PlexServer running on a Edision Mini which is connected, but I do not seem to have the Install Channels option on https://plex.tv/web portal.
Was expecting an be able to do as per the support article https://support.plex.tv/hc/en-us/articles/201053758-Adding-Removing-and-Updating-a-Channel
Go to the main page of Plex Web
on the left side of the screen
take a look at the menu item ‘Channels’ (depending on the number of libraries you’ve created, you might need to scroll all the way down on this left side of the window)
Gerbowers is right. There is no longer an install button in the Channels section as there used to be in previous versions. I am on version 1.10.1.4602 of the Plex Media Player and the Plex Media Server. I am unable to add the Sub-zero agent unless I install it manually, but then I assume I will have to keep it up to date manually too.
You are looking at server settings
Instead look at the left column which lists your libraries. The channels is now referred to as plugins
It’s been removed.
Well I just installed this today and thats the only reason I wanted it for so this service is now useless.
