Mistery with a tv show
What do you mean with nervous?
Could this be a translation problem?
I’ve never said you need to be nervous (only in reaction to you asking why to be nervous earlier).
I mean is my Apple TV navigation nervous?
Or why do I experience the things that another season was marked even though I only went out of one or another season. It always happens to me every third time.
It could be. The touchpad of the remote can be a bit sensitive at times or cause some accidental jumping of the selection.
But I experience there every third time? but what you’re saying is that what I’m experiencing and it has nothing to do with my Apple TV?
Or what?
I Want you to know it.
Sorry, I don’t know the answer.
Why? So you don’t know why its going on? That with Plex.
Why? But is it not my touchpad there are little sensitive?
Or what?
Users are trying to answer to the best of their knowledge.
The idea of your touchpad being a little too sensitive was brought up as an idea. As you also experience this using a different remote, it’s unlikely this is the cause.
Sorry to say it seems we’ve run out of ideas.
If I also experience it with my mobile, what is it then? It can not be with apple tv. i’m not experiencing any other issues with my apple tv. so it can not be so? Or is there something wrong with the series?
The app behavior you have described has nothing to do with the underlying series. So the series itself isn’t causing this.
If you experience the same on a different client this can be linked but it can also be a completely unrelated issue. I’m just wondering a bit how this can even happen on your mobile. The issue you described referred to how the app behaved when using the remote… the mobile doesn’t use a remote at all?!
No, but you can install an Apple TV Remote on your mobile.
But you Can not what the problem cause?
But you do not know what the problem is due to?
Correct. Sadly I have no idea :frowning:
