Mix EPG data from Location & XMLTV
Hello, i’m trying to setup IPTV provider through xteve but i have “an issue” with EPG data. Plex EPG data are better than xmltv data so i first configure a mapping based on location and i’m happy with the result and filters.
However my provider give me more channel not mapped to the location and i have enable a second instance for xteve for those channel with a “manual mapping”. When i try to add the second tuner, i don’t have the option to chose xmltv data provided by xteve and if i first chose the xmltv, i can’t use plex epg by selecting the location.
Is it possible to mix multiple “device” from multiple epg source for different channel ?
Server Version#: 1.28.2.6151
Tuner Make/Model: xteve
Using XMLTV?: Yes
