Not able to combine EPG for Live TV - DVR
Hello Guys,
I recently buy a HDHomeRun SiliconDust Duo, it is working perfectly (which is a good news for me :slight_smile:) and I am using a DS218+ Synology with Plex installed on it.
As I am leaving in Belgium, I have the opportunity to watch TV shows from Belgium and France thanks to the TNT.
The problem appears in Plex when I want to map the scanned channels, I can do it with one EPG provider from France or Belgium.
And because of that, I can’t map all the channels (e.g. The one in France are not available in the one of Belgium)
I choose to map only the French channels and loosing the Belgium ones. But still, as I love my country, I would like to map the Belgium ones.
Do you have any idea to do that? Even with CLI?
If it is not possible, do you have any idea when such kind of functionality will be available?
Thanks in advance for your answers,
Kr,
Zehir
I have not done this, but below are some resources for you. Based on what I’m reading you can currently do this using an XML EPG feed if you are willing to put in some extra work, and there is also a thread requesting that Plex add the functionality natively.
I’m not able to help with any problems or questions, but hopefully this puts you on a path to do what you need…
thanks a lot for your input.
It was so easy but not so clear to see while configuring the TV Live.
btw, just perfect and it answer my needs.
Thanks again,
Zehir
Excellent, glad this helped!
