Server Version#: 1.21.1.3830
Player Version#: 7.23.0.13018
Hello, first time poster here. I have a DVD collection that I would like to convert to MKV and stream through Plex. I wanted to do a trial run with a few movies before I spent a bunch of time converting all of the Media over.
I took a few movies and converted them to MKV using MakeMKV. I have not done any additional encoding/compression using Handbrake, the MKV is unaltered after it was processed through MakeMKV.
I am running Plex server on a fairly high end gaming computer and the MKV files are located on my NAS. The streaming device is an Nvidia Shield Pro connected to a Sony 4K TV. The computer, NAS and Shield are all connected through a Gigabit ethernet network using CAT 6. Nothing is connected via the wireless network. I know I can run the server on the Shield, I just chose to use my computer for now.
Here is my problem. When streaming any of the movies, I notice that the quality is not the same as when I put the DVD in. I have been doing a direct comparison. The streaming quality of the MKV is fairly decent, but I do notice a slight pixilation in some scenes, especially faster motion and scenes that are darker. I also notice a little bit of stuttering from time to time. When I look at the player info, it is Direct Play (mpeg2). So I take that as no transcoding is going on. The DVD runs smooth when played through a PS4 and sets the bar I would like to achieve with the MKVs.
I’m just wondering if this is a limitation of the Shield or rather the MKV/encoding? I have done a ton of research on these forums and have tweaked everything I can on the server side. The quality is set to max, direct play is enabled. Made sure quality is set to max on the PMP also. Even played around with the PMP encoding options. Nothing helped.
Below is the MediaInfo for one Movie I am really struggling with. Not sure if this is helpful, but thought I would go ahead and post it. I appreciate any comments/help you all can offer.
Video
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 1 h 33 min
Bit rate mode : Variable
Bit rate : 6 071 kb/s
Maximum bit rate : 9 800 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 (23976/1000) FPS
Original frame rate : 23.976 (24000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.733
Time code of first frame : 00:59:59:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 3.97 GiB (77%)
Language : English
Default : No
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Original source medium : DVD-Video
