There are a couple changes I’d like to see from mobile syncing.
I find it a pain to grab individual songs, it takes a while and it requires several clicks. For 3 songs on one album I think it would be 9 clicks to do so. A different method would be great - maybe the ability to check off the songs from a list? Maybe the ability to do so from the web interface and push to the mobile device?
I’d also like to see the ability to export the mobile sync to a file. If you change the location of the local media, or lose the content from an SD card, it can be a real pain to re-do all the work of getting several hundred songs back on your phone. If you could just upload a file that already has the sync’d song list and let the system do the rest, that would be great.
Thanks!
