Currently, List View provides 13 possible columns for Title, Year, Duration, etc. There are several other available data points that would be helpful to have as sortable columns. The majority of these suggested columns would be helpful to the admin in order to audit the content to ensure it is all properly titled, tagged, etc.
Name - present the file name of the first item from the Info section of the Edit dialog. If there are multiple files, I’ll know this from the ‘three boxes’ icon and can go to Edit or Get Info to see the others, so I don’t need all of them listed in the List View, especially since the majority will be a single file anyway. But, having the file name presented next to the Title will help verify and validate that the Agent correctly identified the content without having to open Edit or Get Info on every item individually.
Size - I can deduce this from the Bitrate, but there are times when it would be helpful to know which content is taking up the most space in my storage.
Width and Height - There is a Resolution column, but it provides a category of SD, 480, 720, etc without providing the actual numeric resolution. Could be helpful to have additional optional columns that present the numbers.
Tags - A list of the Tags applied to the content.
Collections - A list of the Collections applied to the content.
Genres - A list of the Genres applied to the content.
