Is there any way to have more then one week of guide data available?
You might consider adding a bit more info to your request. IE: TV source (OTA or Cable), cable provider/general area, and the length of guide data you’re currently receiving.
Most likely, Plex is grabbing what Gracenote (Plex’s EPG provider) has to offer. But without more info, I don’t think they can act on your request; if they can at all.
EDIT
Sorry, I did misread slightly. I see that you are only getting one week of guide data. That is odd.
Actually a better request would be, Is there a way for me to use my schedules direct guide data?
I have 2 hd homeruns using m-cards on comcast area code 61615
I am currently waiting for the guide data to re populate “tried a reset of the LIVETV setup”
But before that I was getting about a week.
Thanks for the headsup agentlame…
You can already provide your own guide data if you wish. You need to remove the Tuner(s) and start back from scratch, then carefully answer the questions that follow. I forget the wording but it asks you if you wish to supply your own data during the setup.
seems to be working well now with the gracenote guide. I am trying that out now. implementing schedule direct might be a little daunting. If it passes the wife test i will just stick with stock. Thanks!
