Got it unzipped but not seeing any exe file. How are we supposed to run this update? I feel like Im missing something obvious…
truenas diy machine dedicated to plex
TrueNAS is based on FreeBSD… there’s no .exe files – those only work on Windows.
If you’re not familiar you should try to update the Plex plugin through the TrueNAS’s admin page.
Yeah I’ve tried updating the plug-in and no update is available, it says. The web still says update is available and it’s a patch for the Ddos stuff. Will face this every time there is an update I’d guess.
Which version of the Plex Media Server plug-in do you have installed (Settings > [Server Name] > General > Version; e.g. 1.21.4.4079) and what exact version of TrueNAS are you running it on?
1.21.3.4014, release p-13
From what I understand, “somebody” is packaging those Plex updates for TrueNAS and makes them available. This can cause some delays when the TrueNAS plug-in has not yet been updated, while Plex sees there’s a new version available for the platforms directly supported by Plex.
Not a TrueNAS expert myself, however I’ve found some posts and guides that indicate the way to update will highly depend on how you installed Plex on your TrueNAS:
pkg → use pkgng to update
ports in which case updating your ports would also update the Plex Media ServerThis topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
