Move movies to a different library without losing metadata
Hello,
I currently have one big Library with all my movies in it. I would like to create multiple libraries for multiple languages so that it’s easier to manage.
I tried creating a new library, adding it to my user, and moving a few files in it, but it seems that Plex sees those as completely new files. It created a new entry in the database with a new ID, a fresh “added on” date, and it loses the watched state.
I would like to know if there’s a way to “move” files to a different library without losing this data, without creating a new entry.
Thank you!
Short answer, no.
Long answer, yes. But the amount of work you would have to go through would be the most scariest reality show ever created! (unless you had like 1 movie to move)
Each library is a different entity with it’s own metadata and to compound what is already an ‘almost impossible’ thing, changing languages, you will find the metadata such as plot summary & posters/artwork will be wrong.
Thanks for your answer. That’s what I was suspecting.
How about this: I backup the watched state for all my users (based on unique id like IMDB id or something?), then make all my changes, and once everything is set, I restore the watched state based on that id for all movies for all users. Then I set the “added on” to the file creation date, which would fix the recently added, mostly.
Does that plan make sense? Or did I overlook something?
