Move PMS Database from Synology DS415+ to QNAP TVS-671 NAS
Hello everybody, i just bought a new NAS from Qnap, Now i already tranfered the hole data from my Synology to the QNAP. After that i tried this guide Klick Me. But after restarting the System i couldn’t find any data in the PMS Web Interface! I Idont’t want to start from the beginning. What did i wrong? Is theire i guide to move Plex from QNAP to Synology? Because i found nothing in the www. Can anyone help me with my special Problem? The Metadata isn’t that importened but the watched status should be transfered ! Sry for my bad english Skills.
My guess is the IP address !
Well i’m able to connect to the PMS on the QNAP. But i doesn’t show any Libaries
You must redo you libraries locations.
Your watched list and metatags will all be there but the media is in a different place to your old NAS
I know but after adding the media to my libary it shows the unwatched state but on old PMS it was already watched.Normaly there should be the existing/previous folder location from the old PMS. I think the main Problem ist that this guide ist only if u move from one system to another with the same OS.
Is theire any other way to transfer the watched list from PMS to PMS? Specially the TV Shows
Did you change (or re-add) the media folders locations ??
If u did, the watched will be already there
The watched list are in this DB
\NAS\Plex\Library\Application Support\Plex Media Server\Plug-in Support\Databases*com.plexapp.plugins.library.db*
And that hold the locations of your media
And delete these two in the folder above.
com.plexapp.plugins.library.db-wal
and com.plexapp.plugins.library.db-shm
Thank you so much! I just deleted the 2 files! And et voila everything worked
Yeh ha - Great news
