I upgraded to DSM7 on my DS920+ and didn’t realize the changes that were made would make copying the plex system easily to another platform. Since rebuilding my entire library, I have decided to move to a QNAP NAS. Is there anyway in which I can move from synology to qnap without having to rebuild my entire library again?
First off, let me thank you for these instructions, they were extremely helpful and made what I thought would be a difficult process quite easy. However, I have run into one bump in the road. In both of my movie libraries in Plex I have a number of collections that I made. However, one of the libraries, the largest one, did not migrate the collections over to the new install. The other library worked just fine, but my main one did not. When I click on collections under that library, it just reshows the library itself, not the collections. So, what can I do? Is it possible to get just my collections for that library back or would I have to reinstall completely from scratch? Is a reinstall even possible now? I really would like a solution to get the collections back for that one library. Thank you for your help.
Okay, so when I got home I checked the client and the collections showed up just fine. The Web client is not working well. After all the updating is finished, I will close it and restart again to see if that clears it up on the web client.
The collections info is in the database, so if you moves that over correctly, it should have just worked. However, when you were changing changing the media paths (step 12 above), it’s possible things didn’t get matched properly so the old collection information for those movies got lost. The collection itself should still exist, they just might be empty.
So, I downloaded the app for my QNAP from Plex and installed that one. To get to the web client I just click on open in the QNAP and a page opens up with my plex library.
Also, let me tell you this. When I did step 12 above for the QNAP I accidently did all the libraries before I did steps “Empty Trash, Clean Bundles, and Optimize Database.” I was supposed to do each library completely one at time, per instructions. Would that have missed up on the set of collections, but left the other one intact?
If it is only Web that isn’t presenting the collections info, then your move sounds like it worked. Something in Web just isn’t working right.
That is the bundled version. Try using the hosted one. Go to plex.tv, sign into your Plex account, hit the launch button at the top right or just go to https://app.plex.tv/desktop/#!/. See if that’s any different.
You can also edit one of your movies, go to the tags page, scroll down to the bottom to the collections field. Is the name of the collection you expect listed there?
Okay tried these ideas. The web client is still not showing the collections, however, when I tried to add a movie to a collection, all the collection were listed. They just don’t appear under the collections tab.
