Movie does not show correctly with PlexConnect
I have a strange problem regarding just one movie, parameters for this file are attached.
The Problem is, that sound is played everytime, but I just can see the correct picture if I play the file via airplay to the Apple TV. If I use PlexConnect with Apple TV or Google TV I just get image flickers. Playing the movie at the PC with Firefox also works fine. Has anyone an idea?
Video
  • Container mkv
  • Codec H264
  • Bitrate 25252 kbps
  • Bit Depth 8
  • CABAC 1
  • Chroma Subsampling 4:2:0
  • Color Space yuv
  • Dauer 2:02:41
  • Bildrate 23,976 fps
  • Frame Rate Mode cfr
  • Has Scaling Matrix 0
  • Height 1080
  • Ebene 4.1
  • Profil high
  • Ref Frames 2
  • Scan Type progressive
  • Width 1920
Audio
  • Codec AC3
  • Kanäle 5.1
  • Bitrate 640 kbps
  • Sprache Deutsch
  • Bit Depth 16
  • Bitratenmodus CBR
  • Dialog Norm -31 dB
  • Dauer 2:02:41
  • Abtastfrequenz 48000 Hz
What os are you running?
OS of the Plex Server is Windows Server 2012 R2
PMS Version: 0.9.8.6.175-88ffbb2
ATV 3
What happens if you try and play it directly on your iPad/iPhone in the Plex app?
Log with level set to ‘High’?
Playing this specific file directly on my iPhone in the Plex app works. Video and Audio are fine, no problems.
Here is a detail of the log file:
Oct 31, 2013 13:18:25:232 [1276] DEBUG - [Transcoder] Thread count: 4
Oct 31, 2013 13:18:25:247 [1840] DEBUG - [Transcoder] Input #0, matroska,webm, from 'http://127.0.0.1:32400/library/parts/2254/file.mkv':
Oct 31, 2013 13:18:25:247 [1276] DEBUG - [Transcoder]     Stream #0.0, 68, 1/1000: Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9]
Oct 31, 2013 13:18:25:263 [1052] DEBUG - [Transcoder]     Stream #0.1(ger), 90, 1/1000: Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
Oct 31, 2013 13:18:25:278 [1276] DEBUG - [Transcoder]     Stream #0.2(eng), 90, 1/1000: Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
Oct 31, 2013 13:18:25:278 [1052] DEBUG - [Transcoder]     Stream #0.3(ger), 0, 1/1000: Subtitle: dvdsub
Oct 31, 2013 13:18:25:294 [1276] DEBUG - [Transcoder]     Stream #0.4(eng), 0, 1/1000: Subtitle: dvdsub
Oct 31, 2013 13:18:25:310 [1052] DEBUG - [Transcoder]     Stream #0.5(fre), 0, 1/1000: Subtitle: dvdsub
Oct 31, 2013 13:18:25:325 [1276] DEBUG - [Transcoder]     Stream #0.6(dut), 0, 1/1000: Subtitle: dvdsub
Oct 31, 2013 13:18:25:341 [1052] DEBUG - [Transcoder]     Stream #0.7(tur), 0, 1/1000: Subtitle: dvdsub
Oct 31, 2013 13:18:25:341 [1276] DEBUG - [Transcoder] Applying output settings.
Oct 31, 2013 13:18:25:357 [4812] DEBUG -  [FFMPEG] Duration: 7361.38
Oct 31, 2013 13:18:25:357 [4812] DEBUG - Read line, and done: 1
Oct 31, 2013 13:18:25:357 [4812] DEBUG - Started session successfully: EB8C138D-2793-4647-AA31-431008C92253
Oct 31, 2013 13:18:25:357 [4812] DEBUG - HLS: Building an M3U8 for 7362 total seconds with 3 seconds/segment, target duration of 3.
Oct 31, 2013 13:18:25:357 [1052] DEBUG - [Transcoder] Frames per second is either 23.976025 or 23.976024.
Oct 31, 2013 13:18:25:357 [1276] DEBUG - [Transcoder] Final font scale: 1.500000 (0.750000) -> 1.221429
Oct 31, 2013 13:18:25:357 [1840] DEBUG - [Transcoder] Audio stream info:
Oct 31, 2013 13:18:25:372 [1052] DEBUG - [Transcoder]     codec_id  : 15003
Oct 31, 2013 13:18:25:388 [1840] DEBUG - [Transcoder]     channels  : 6
Oct 31, 2013 13:18:25:388 [1276] DEBUG - [Transcoder]     bitrate   : 640000/128000
Oct 31, 2013 13:18:25:403 [1052] DEBUG - [Transcoder]     samplerate: 48000
Oct 31, 2013 13:18:25:419 [1840] DEBUG - [Transcoder]     audiogain : 1.00 (256)
Oct 31, 2013 13:18:25:435 [1276] DEBUG - [Transcoder]     aacProfile: 1/-99
Oct 31, 2013 13:18:25:435 [4812] DEBUG - [Transcoder]     ----> ac3 is not supported
Oct 31, 2013 13:18:25:450 [1052] DEBUG - [Transcoder] Video stream info:
Oct 31, 2013 13:18:25:451 [4812] DEBUG - [Transcoder]     codec_id: 1c/1c
Oct 31, 2013 13:18:25:451 [1840] DEBUG - [Transcoder]     level   : 41/31
Oct 31, 2013 13:18:25:451 [1276] DEBUG - [Transcoder]     avg_fps : 24/24
Oct 31, 2013 13:18:25:467 [1052] DEBUG - [Transcoder]     profile : 64/4d
Oct 31, 2013 13:18:25:482 [1276] DEBUG - [Transcoder]     vfr     : 0
Oct 31, 2013 13:18:25:498 [4812] DEBUG - [Transcoder]     fps     : 23.98/23.98
Oct 31, 2013 13:18:25:519 [1840] DEBUG - [Transcoder]     bitrate : 25.79/4.19 mbps
Oct 31, 2013 13:18:25:535 [1276] DEBUG - [Transcoder]     height  : 1080/720
Oct 31, 2013 13:18:25:535 [1052] DEBUG - [Transcoder]     aspect  : 0.56(1.00)/0.56
Oct 31, 2013 13:18:25:551 [1840] DEBUG - [Transcoder]     segSize : 75.62mbits/seg, 25.21/25.60MBps
Oct 31, 2013 13:18:25:566 [1052] DEBUG - [Transcoder]     timebase: 0.02085(1001:48000)/0.00001(0:1000000)
Oct 31, 2013 13:18:25:582 [4812] DEBUG - [Transcoder]     ----> Level Failed
Oct 31, 2013 13:18:25:582 [1276] DEBUG - [Transcoder] Configuring output.
Oct 31, 2013 13:18:25:650 [1840] DEBUG - [Transcoder] Output #0, mpegts, to 'C:\Users\ADMINI~1\AppData\Local\Temp\2\plex-transcode-EB8C138D-2793-4647-AA31-431008C92253-9d6581b7-afd3-4ff5-8422-d2f2aa192517-tmp.ts':
Oct 31, 2013 13:18:25:650 [1052] DEBUG - [Transcoder]     Stream #0.0, 0, 1/90000: Video: libx264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=10-51, 200 kb/s
Oct 31, 2013 13:18:25:666 [4812] DEBUG - [Transcoder]     Stream #0.1(ger), 0, 1/90000: Audio: libmp3lame, 48000 Hz, 2 channels, s16, 128 kb/s
Oct 31, 2013 13:18:25:666 [1276] DEBUG - [Transcoder] The verbose setting is 0 and PLEX_DEBUG is 0.
Oct 31, 2013 13:18:25:705 [1840] DEBUG - Request: GET /video/:/transcode/segmented/session/EB8C138D-2793-4647-AA31-431008C92253/8/00000.ts [192.168.178.72:51177] (5 live)
Oct 31, 2013 13:18:25:705 [1840] DEBUG - Asked for segment 0 from session.
Oct 31, 2013 13:18:27:335 [4812] DEBUG - [Transcoder] Wrote segment 0 (2.83s, 2.83s, 0.30mb)
Oct 31, 2013 13:18:27:350 [1840] DEBUG - Returning segment 0 from session: C:\Users\ADMINI~1\AppData\Local\Temp\2\plex-transcode-EB8C138D-2793-4647-AA31-431008C92253-9d6581b7-afd3-4ff5-8422-d2f2aa192517\media-00000.ts
Oct 31, 2013 13:18:27:350 [1840] DEBUG - Content-Length of C:\Users\ADMINI~1\AppData\Local\Temp\2\plex-transcode-EB8C138D-2793-4647-AA31-431008C92253-9d6581b7-afd3-4ff5-8422-d2f2aa192517\media-00000.ts is 315276.
Oct 31, 2013 13:18:27:683 [1052] DEBUG - Request: PUT /video/:/transcode/session/EB8C138D-2793-4647-AA31-431008C92253/progress?progress=0.0&size=0&speed=1.8&remaining=3998 [127.0.0.1:60299] (5 live)
Sorry I just noticed that you get the same issue with the Google TV version of Plex.
I would suggest raising it in the PMS sub forum as it is not specific to PlexConnect - it is much more likely to be a bug in the transcoded or similar.
