Hello, who can help me out?
No Errors in PlexConnect Log (at log level high), Plex Media Server running on FreeBSD 10.1, 6-core Intel Xenon CPU, 64 GB ram.
Tried different encoding settings (higher speed, make my cpu hurt)
Settings in plexconnect config 'auto' for transcoding and subtitles.
AppleTV jumps back to mainscreen, movie keeps playing in PMS and is timing out after 1 minute, and nothing in plexconnect log after "18:38:17 ATVLogger: Player state: Playing at this time: 210" line
When I set plexconnect config to 'transcode' then plays for about 30 minutes and stops playing, spinning wheel, and buffering.
Processor load not even 1%.
Atv connected via ethernet to gigabit switch.
How to debug?
Regards,
Donald.
PlexConnect.log
Accept: */*
Accept-Language: en;q=0.9
Cookie: s_vi=[CS]v1|2A3115FF05010EC8-6000013500001285[CE]
X-Apple-TV-Resolution: 1080
X-Apple-TV-Version: 7.0.2
User-Agent: AppleTV/7.0.2 iOS/8.1.1 AppleTV/7.0.2 model/AppleTV3,2 build/12B435 (3; dt:12)
Cache-Control: max-age=259200
X-Forwarded-For: 10.0.0.1
X-Forwarded-Host: trailers.apple.com
X-Forwarded-Server: trailers.apple.com
Connection: Keep-Alive
18:37:44 WebServer: http request path:
/js/selectAudioAndSubs.js
18:37:44 Localize: aTVLanguage: en
18:37:44 WebServer: pms address:
18:37:44 WebServer: cleaned path:
18:37:44 WebServer: PlexConnect options:
{'aTVScreenResolution': '1080', 'aTVFirmwareVersion': '7.0.2', 'aTVLanguage': 'en', 'aTVAddress': '10.0.0.1'}
18:37:44 WebServer: additional arguments:
18:37:44 WebServer: serving /js/selectAudioAndSubs.js
18:38:05 WebServer: http request header:
X-Apple-Store-Front: 143452-2,19
Accept: */*
Accept-Encoding: gzip, deflate
18:38:05 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=loadURL%20(override)%3A%20http%3A%2F%2Ftrailers.apple.com%2FPMS(10.0.0.1)%2Flibrary%2Fmetadata%2F74962%3FincludeExtras%3D1%26PlexConnect%3DPlay%3A%3A74962
18:38:05 Localize: aTVLanguage: en
18:38:05 WebServer: pms address:
18:38:05 WebServer: cleaned path:
18:38:05 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'loadURL (override): http://trailers.apple.com/PMS(10.0.0.1)/library/metadata/74962?includeExtras=1&PlexConnect=Play::74962', 'aTVFirmwareVersion': '7.0.2', 'aTVLanguage': 'en'}
18:38:05 WebServer: additional arguments:
18:38:05 ATVLogger: loadURL (override): http://trailers.apple.com/PMS(10.0.0.1)/library/metadata/74962?includeExtras=1&PlexConnect=Play::74962
Accept: */*
Accept-Language: en
Cookie: ns-mzf-inst=39-120-80-145-7-8101-362303-36-nk11; xp_ci=3z1dsQyDz8Mmz4kNzAYwzHdMDDcOD; mz_at0-1100468873=AwQAAAEMAAE45QAAAABUeKwxYHJCBTSNGmghIqxq/vBBkvMg8Sw=; s_vi=[CS]v1|2A31163E050134B5-40000101600171B4[CE]; Pod=36; itspod=36
Cache-Control: max-age=0
/PMS(10.0.0.1)/library/metadata/74962?includeExtras=1&PlexConnect=Play::74962&PlexConnectUDID=DY3ND6HLFF54&PlexConnectATVName=Apple%20TV
10.0.0.1
{'aTVAddress': '10.0.0.1', 'aTVLanguage': 'en', 'PlexConnectUDID': 'DY3ND6HLFF54', 'aTVScreenResolution': '1080', 'aTVFirmwareVersion': '7.0.2', 'PlexConnectATVName': 'Apple TV', 'PlexConnect': 'Play::74962'}
?includeExtras=1
18:38:05 WebServer: serving .xml: /library/metadata/74962
18:38:05 XMLConverter: PlexConnect Cmd: Play::74962
18:38:05 XMLConverter: PlexConnectChannelsSearch:
18:38:05 PlexAPI: URL: http://10.0.0.1:32400/library/metadata/74962?includeExtras=1
18:38:05 PlexAPI: xargs: {'X-Plex-Token': 'gNgiPs5nQeba59yJqYpy', 'X-Plex-Platform': 'iOS', 'X-Plex-Model': '3,1', 'X-Plex-Client-Platform': 'iOS', 'X-Plex-Client-Identifier': 'DY3ND6HLFF54', 'X-Plex-Device': 'AppleTV', 'X-Plex-Product': 'PlexConnect', 'X-Plex-Platform-Version': '7.0.2', 'X-Plex-Device-Name': 'Apple TV', 'X-Plex-Version': '0.4-dev'}
18:38:05 PlexAPI: ====== received PMS-XML ======
18:38:05 PlexAPI:
18:38:05 PlexAPI: ====== PMS-XML finished ======
18:38:05 XMLConverter: viewGroup: None
18:38:05 XMLConverter: XMLTemplate: PlayVideo.xml
18:38:05 XMLConverter: XML_ExpandNode:
{{COPY(Video:ratingKey::=|{{VAL_QUOTED(^PlexConnectRatingKey)}}=COPY|{{VAL_QUOTED(^PlexConnectRatingKey)}} =)}}
18:38:05 XMLConverter: XML_ExpandLine: Video:ratingKey::=|{{VAL_QUOTED(^PlexConnectRatingKey)}}=COPY|{{VAL_QUOTED(^PlexConnectRatingKey)}} =
18:38:05 XMLConverter: CCmds_getParam: ^PlexConnectRatingKey,
18:38:05 XMLConverter: CCmds_getParam: ,
18:38:05 XMLConverter: CCmds_getKey: 74962,,False
18:38:05 XMLConverter: CCmds_getConversion: [],
18:38:05 XMLConverter: CCmds_applyConversion: 74962
18:38:05 XMLConverter: XML_ExpandLine: Video:ratingKey::=|74962=COPY|{{VAL_QUOTED(^PlexConnectRatingKey)}} = - done
18:38:05 XMLConverter: XML_ExpandLine: Video:ratingKey::=|74962=COPY|74962 = - done
18:38:05 XMLConverter: CCmds_getParam: Video, ratingKey::=|74962=COPY|74962 =
18:38:05 XMLConverter: CCmds_getParam: ratingKey, :=|74962=COPY|74962 =
18:38:05 XMLConverter: CCmds_getParam: , =|74962=COPY|74962 =
18:38:05 XMLConverter: CCmds_getKey: 74962,=|74962=COPY|74962 =,False
18:38:05 XMLConverter: CCmds_getParam: =|74962=COPY|74962 =,
18:38:05 XMLConverter: CCmds_getConversion: [('', ''), ('74962', 'COPY'), ('74962 ', '')],
18:38:05 XMLConverter: CCmds_applyConversion: COPY
18:38:05 XMLConverter: XML_ExpandNode: {{VIDEOURL()}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VIDEOURL in line {{VIDEOURL()}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(title)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(title)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(summary)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(summary)}}
18:38:05 XMLConverter: XML_ExpandNode: {{EVAL({{VAL(viewOffset:0)}} / 1000)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over EVAL in line {{EVAL({{VAL(viewOffset:0)}} / 1000)}}
18:38:05 XMLConverter: XML_ExpandNode: {{IMAGEURL(thumb::384)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over IMAGEURL in line {{IMAGEURL(thumb::384)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(%baseURL)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(%baseURL)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(%accesstoken)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(%accesstoken)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL($showplayerclock)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL($showplayerclock)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL($timeformat)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL($timeformat)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL($clockposition)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL($clockposition)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL($overscanadjust)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL($overscanadjust)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL($showendtime)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL($showendtime)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL($subtitlesize)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL($subtitlesize)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(key)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(key)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(ratingKey)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(ratingKey)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(duration)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(duration)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(Media/Part/duration)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(Media/Part/duration)}}
{{COPY(Media/Part/Stream:streamType::=|3=COPY|3 =)}}
18:38:05 XMLConverter: CCmds_getParam: Media/Part/Stream, streamType::=|3=COPY|3 =
18:38:05 XMLConverter: CCmds_getParam: streamType, :=|3=COPY|3 =
18:38:05 XMLConverter: CCmds_getParam: , =|3=COPY|3 =
18:38:05 XMLConverter: CCmds_getKey: 1,=|3=COPY|3 =,False
18:38:05 XMLConverter: CCmds_getParam: =|3=COPY|3 =,
18:38:05 XMLConverter: CCmds_getConversion: [('', ''), ('3', 'COPY'), ('3 ', '')],
18:38:05 XMLConverter: CCmds_getKey: 2,=|3=COPY|3 =,False
18:38:05 XMLConverter: CCmds_getKey: 3,=|3=COPY|3 =,False
{{CUT(selected:CUT:0=CUT|1=)}}
{{URL(key)}}&PlexConnect=Subtitle&PlexConnectSubtitleFormat={{VAL(format)}}
18:38:05 XMLConverter: CCmds_getParam: selected, CUT:0=CUT|1=
18:38:05 XMLConverter: CCmds_getParam: CUT, 0=CUT|1=
18:38:05 XMLConverter: CCmds_getKey: CUT,0=CUT|1=,True
18:38:05 XMLConverter: CCmds_getParam: 0=CUT|1=,
18:38:05 XMLConverter: CCmds_getConversion: [('0', 'CUT'), ('1', '')],
18:38:05 XMLConverter: CCmds_getKey: 1,0=CUT|1=,False
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over URL in line
18:38:05 XMLConverter: XML_ExpandLine: {{URL(key)}}&PlexConnect=Subtitle&PlexConnectSubtitleFormat={{VAL(format)}}
18:38:05 XMLConverter: CCmds_getParam: key,
18:38:05 XMLConverter: CCmds_getKey: /library/streams/183499,,False
18:38:05 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(10.0.0.1)/library/streams/183499&PlexConnect=Subtitle&PlexConnectSubtitleFormat={{VAL(format)}} - done
18:38:05 XMLConverter: CCmds_getParam: format,
18:38:05 XMLConverter: CCmds_getKey: srt,,False
18:38:05 XMLConverter: CCmds_applyConversion: srt
18:38:05 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(10.0.0.1)/library/streams/183499&PlexConnect=Subtitle&PlexConnectSubtitleFormat=srt - done
{{COPY_PLAYLIST(@main/Video:^PlexConnectPlayType::^PlexConnectRatingKey::ratingKey:)}}
18:38:05 XMLConverter: CCmds_getParam: @main/Video, ^PlexConnectPlayType::^PlexConnectRatingKey::ratingKey:
18:38:05 XMLConverter: CCmds_getParam: ^PlexConnectPlayType, :^PlexConnectRatingKey::ratingKey:
18:38:05 XMLConverter: CCmds_getParam: , ^PlexConnectRatingKey::ratingKey:
18:38:05 XMLConverter: CCmds_getKey: ,^PlexConnectRatingKey::ratingKey:,False
18:38:05 XMLConverter: CCmds_getParam: ^PlexConnectRatingKey, :ratingKey:
18:38:05 XMLConverter: CCmds_getParam: , ratingKey:
18:38:05 XMLConverter: CCmds_getKey: 74962,ratingKey:,False
{{VAR(partIndex::-1)}}
{{COPY(Media/Part)}}
18:38:05 XMLConverter: CCmds_getParam: partIndex, :-1
18:38:05 XMLConverter: CCmds_getParam: , -1
18:38:05 XMLConverter: CCmds_getParam: -1,
18:38:05 XMLConverter: CCmds_getKey: -1,,True
18:38:05 XMLConverter: CCmds_getParam: Media/Part,
18:38:05 XMLConverter: XML_ExpandNode: {{VIDEOURL(@copy_Video:#partIndex)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VIDEOURL in line {{VIDEOURL(@copy_Video:#partIndex)}}
{{VAR(partIndex::{{EVAL({{VAL(#partIndex)}}+1)}})}}
18:38:05 XMLConverter: XML_ExpandLine: partIndex::{{EVAL({{VAL(#partIndex)}}+1)}}
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(#partIndex)}}+1
18:38:05 XMLConverter: CCmds_getParam: #partIndex,
18:38:05 XMLConverter: CCmds_getKey: -1,,False
18:38:05 XMLConverter: CCmds_applyConversion: -1
18:38:05 XMLConverter: XML_ExpandLine: -1+1 - done
18:38:05 XMLConverter: XML_ExpandLine: partIndex::0 - done
18:38:05 XMLConverter: CCmds_getParam: partIndex, :0
18:38:05 XMLConverter: CCmds_getParam: , 0
18:38:05 XMLConverter: CCmds_getParam: 0,
18:38:05 XMLConverter: CCmds_getKey: 0,,True
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(@copy_Video/title)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(@copy_Video/title)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(@copy_Video/summary)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(@copy_Video/summary)}}
18:38:05 XMLConverter: XML_ExpandNode: {{IMAGEURL(@copy_Video/thumb::384)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over IMAGEURL in line {{IMAGEURL(@copy_Video/thumb::384)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(@copy_Video/key)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(@copy_Video/key)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(@copy_Video/ratingKey)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(@copy_Video/ratingKey)}}
18:38:05 XMLConverter: XML_ExpandNode: {{VAL(@copy_Video/duration)}}
18:38:05 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(@copy_Video/duration)}}
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(key)}}
18:38:05 XMLConverter: CCmds_getKey: /library/parts/111184/file.mkv,,False
18:38:05 XMLConverter: CCmds_applyConversion: /library/parts/111184/file.mkv
18:38:05 XMLConverter: XML_ExpandLine: /library/parts/111184/file.mkv - done
18:38:05 XMLConverter: XML_ExpandLine: {{VIDEOURL(@copy_Video:#partIndex)}}
18:38:05 XMLConverter: CCmds_getParam: @copy_Video, #partIndex
18:38:05 XMLConverter: CCmds_getKey: 0,,False
18:38:05 ATVSettings: getsetting Auto
18:38:05 XMLConverter: video: ATVNative - False
18:38:05 ATVSettings: getsetting 1080p 40.0Mbps
18:38:05 XMLConverter: subtitle: IOSNative - False, PlexConnect - True, DirectPlay - True
18:38:05 ATVSettings: getsetting 100
18:38:05 PlexAPI: Setting transcode quality Res:1920x1080 Q:100 40000Mbps
18:38:05 PlexAPI: Subtitle: selected 1, dontBurnIn 1, size 100
18:38:05 PlexAPI: Audio: boost 100
18:38:05 XMLConverter: VideoURL: http://10.0.0.1:32400/video/:/transcode/universal/start.m3u8?maxVideoBitrate=40000&videoQuality=100&subtitleSize=100&fastSeek=1&partIndex=0&session=DY3ND6HLFF54&skipSubtitles=1&audioBoost=100&protocol=hls&path=%2Flibrary%2Fmetadata%2F74962&videoResolution=1920x1080&directStream=1&X-Plex-Token=gNgiPs5nQeba59yJqYpy&X-Plex-Platform=iOS&X-Plex-Model=3%2C1&X-Plex-Client-Capabilities=protocols%3Dhttp-live-streaming%2Chttp-mp4-streaming%2Chttp-streaming-video%2Chttp-streaming-video-720p%2Chttp-mp4-video%2Chttp-mp4-video-720p%3BvideoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A41%7D%3BaudioDecoders%3Dmp3%2Caac%7Bbitrate%3A160000%7D&X-Plex-Client-Platform=iOS&X-Plex-Client-Identifier=DY3ND6HLFF54&X-Plex-Device=AppleTV&X-Plex-Product=PlexConnect&X-Plex-Platform-Version=7.0.2&X-Plex-Device-Name=Apple+TV&X-Plex-Version=0.4-dev
18:38:05 XMLConverter: XML_ExpandLine: http://10.0.0.1:32400/video/:/transcode/universal/start.m3u8?maxVideoBitrate=40000&videoQuality=100&subtitleSize=100&fastSeek=1&partIndex=0&session=DY3ND6HLFF54&skipSubtitles=1&audioBoost=100&protocol=hls&path=%2Flibrary%2Fmetadata%2F74962&videoResolution=1920x1080&directStream=1&X-Plex-Token=gNgiPs5nQeba59yJqYpy&X-Plex-Platform=iOS&X-Plex-Model=3%2C1&X-Plex-Client-Capabilities=protocols%3Dhttp-live-streaming%2Chttp-mp4-streaming%2Chttp-streaming-video%2Chttp-streaming-video-720p%2Chttp-mp4-video%2Chttp-mp4-video-720p%3BvideoDecoders%3Dh264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A41%7D%3BaudioDecoders%3Dmp3%2Caac%7Bbitrate%3A160000%7D&X-Plex-Client-Platform=iOS&X-Plex-Client-Identifier=DY3ND6HLFF54&X-Plex-Device=AppleTV&X-Plex-Product=PlexConnect&X-Plex-Platform-Version=7.0.2&X-Plex-Device-Name=Apple+TV&X-Plex-Version=0.4-dev - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(@copy_Video/title)}}
18:38:05 XMLConverter: CCmds_getParam: @copy_Video/title,
18:38:05 XMLConverter: CCmds_getKey: Gravity,,False
18:38:05 XMLConverter: CCmds_applyConversion: Gravity
18:38:05 XMLConverter: XML_ExpandLine: Gravity - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(@copy_Video/summary)}}
18:38:05 XMLConverter: CCmds_getParam: @copy_Video/summary,
18:38:05 XMLConverter: CCmds_getKey: Dr. Ryan Stone (Sandra Bullock) is een briljante medische ingenieur die op haar eerste shuttlemissie gaat met de ervaren astronaut Matt Kowalsky (George Clooney), die het commando heeft over zijn laatste vlucht voor hij met pensioen gaat. Maar een schijnbaar routine ruimtewandeling draait uit op een ramp. De shuttle wordt vernietigd waardoor Stone en Kowalsky alleen achterblijven ? vastgeketend aan elkaar en steeds verder zwevend in het duister. De oorverdovende stilte verraadt dat ze elke link met de Aarde verloren hebben ... en elke kans op redding. Angst wordt paniek, en elke hap lucht vermindert de nog resterende hoeveelheid zuurstof. Maar misschien is de enige weg naar huis verder te gaan in de angstaanjagende uitgestrektheid van de ruimte.,,False
18:38:05 XMLConverter: CCmds_applyConversion: Dr. Ryan Stone (Sandra Bullock) is een briljante medische ingenieur die op haar eerste shuttlemissie gaat met de ervaren astronaut Matt Kowalsky (George Clooney), die het commando heeft over zijn laatste vlucht voor hij met pensioen gaat. Maar een schijnbaar routine ruimtewandeling draait uit op een ramp. De shuttle wordt vernietigd waardoor Stone en Kowalsky alleen achterblijven ? vastgeketend aan elkaar en steeds verder zwevend in het duister. De oorverdovende stilte verraadt dat ze elke link met de Aarde verloren hebben ... en elke kans op redding. Angst wordt paniek, en elke hap lucht vermindert de nog resterende hoeveelheid zuurstof. Maar misschien is de enige weg naar huis verder te gaan in de angstaanjagende uitgestrektheid van de ruimte.
18:38:05 XMLConverter: XML_ExpandLine: Dr. Ryan Stone (Sandra Bullock) is een briljante medische ingenieur die op haar eerste shuttlemissie gaat met de ervaren astronaut Matt Kowalsky (George Clooney), die het commando heeft over zijn laatste vlucht voor hij met pensioen gaat. Maar een schijnbaar routine ruimtewandeling draait uit op een ramp. De shuttle wordt vernietigd waardoor Stone en Kowalsky alleen achterblijven ? vastgeketend aan elkaar en steeds verder zwevend in het duister. De oorverdovende stilte verraadt dat ze elke link met de Aarde verloren hebben ... en elke kans op redding. Angst wordt paniek, en elke hap lucht vermindert de nog resterende hoeveelheid zuurstof. Maar misschien is de enige weg naar huis verder te gaan in de angstaanjagende uitgestrektheid van de ruimte. - done
18:38:05 XMLConverter: XML_ExpandLine: {{IMAGEURL(@copy_Video/thumb::384)}}
18:38:05 XMLConverter: CCmds_getParam: @copy_Video/thumb, :384
18:38:05 XMLConverter: CCmds_getParam: , 384
18:38:05 XMLConverter: CCmds_getKey: /library/metadata/74962/thumb/1410703264,384,False
18:38:05 XMLConverter: CCmds_getParam: 384,
18:38:05 XMLConverter: photo: ATVNative - False
18:38:05 XMLConverter: ImageURL: http://10.0.0.1:32400/photo/:/transcode/384x384/http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F74962%2Fthumb%2F1410703264?url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F74962%2Fthumb%2F1410703264&width=384&X-Plex-Token=gNgiPs5nQeba59yJqYpy&height=384
18:38:05 XMLConverter: XML_ExpandLine: http://10.0.0.1:32400/photo/:/transcode/384x384/http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F74962%2Fthumb%2F1410703264?url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F74962%2Fthumb%2F1410703264&width=384&X-Plex-Token=gNgiPs5nQeba59yJqYpy&height=384 - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(@copy_Video/key)}}
18:38:05 XMLConverter: CCmds_getParam: @copy_Video/key,
18:38:05 XMLConverter: CCmds_getKey: /library/metadata/74962,,False
18:38:05 XMLConverter: CCmds_applyConversion: /library/metadata/74962
18:38:05 XMLConverter: XML_ExpandLine: /library/metadata/74962 - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(@copy_Video/ratingKey)}}
18:38:05 XMLConverter: CCmds_getParam: @copy_Video/ratingKey,
18:38:05 XMLConverter: XML_ExpandLine: 74962 - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(@copy_Video/duration)}}
18:38:05 XMLConverter: CCmds_getParam: @copy_Video/duration,
18:38:05 XMLConverter: CCmds_getKey: 5458500,,False
18:38:05 XMLConverter: CCmds_applyConversion: 5458500
18:38:05 XMLConverter: XML_ExpandLine: 5458500 - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(duration)}}
18:38:05 XMLConverter: CCmds_getParam: duration,
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(^PlexConnectRatingKey)}}
18:38:05 XMLConverter: XML_ExpandLine: {{VIDEOURL()}}
18:38:05 XMLConverter: CCmds_getKey: ,,True
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(title)}}
18:38:05 XMLConverter: CCmds_getParam: title,
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(summary)}}
18:38:05 XMLConverter: CCmds_getParam: summary,
18:38:05 XMLConverter: XML_ExpandLine: {{EVAL({{VAL(viewOffset:0)}} / 1000)}}
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(viewOffset:0)}} / 1000
18:38:05 XMLConverter: CCmds_getParam: viewOffset, 0
18:38:05 XMLConverter: CCmds_getKey: 218601,,False
18:38:05 XMLConverter: CCmds_applyConversion: 218601
18:38:05 XMLConverter: XML_ExpandLine: 218601 / 1000 - done
18:38:05 XMLConverter: XML_ExpandLine: 218 - done
18:38:05 XMLConverter: XML_ExpandLine: {{IMAGEURL(thumb::384)}}
18:38:05 XMLConverter: CCmds_getParam: thumb, :384
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(%baseURL)}}
18:38:05 XMLConverter: CCmds_getParam: %baseURL,
18:38:05 XMLConverter: CCmds_getKey: http://10.0.0.1:32400,,False
18:38:05 XMLConverter: CCmds_applyConversion: http://10.0.0.1:32400
18:38:05 XMLConverter: XML_ExpandLine: http://10.0.0.1:32400 - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(%accesstoken)}}
18:38:05 XMLConverter: CCmds_getParam: %accesstoken,
18:38:05 XMLConverter: CCmds_getKey: gNgiPs5nQeba59yJqYpy,,False
18:38:05 XMLConverter: CCmds_applyConversion: gNgiPs5nQeba59yJqYpy
18:38:05 XMLConverter: XML_ExpandLine: gNgiPs5nQeba59yJqYpy - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL($showplayerclock)}}
18:38:05 XMLConverter: CCmds_getParam: $showplayerclock,
18:38:05 ATVSettings: getsetting True
18:38:05 XMLConverter: CCmds_getKey: True,,False
18:38:05 XMLConverter: CCmds_applyConversion: True
18:38:05 XMLConverter: XML_ExpandLine: True - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL($timeformat)}}
18:38:05 XMLConverter: CCmds_getParam: $timeformat,
18:38:05 ATVSettings: getsetting 24 Hour
18:38:05 XMLConverter: CCmds_getKey: 24 Hour,,False
18:38:05 XMLConverter: CCmds_applyConversion: 24 Hour
18:38:05 XMLConverter: XML_ExpandLine: 24 Hour - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL($clockposition)}}
18:38:05 XMLConverter: CCmds_getParam: $clockposition,
18:38:05 ATVSettings: getsetting Center
18:38:05 XMLConverter: CCmds_getKey: Center,,False
18:38:05 XMLConverter: CCmds_applyConversion: Center
18:38:05 XMLConverter: XML_ExpandLine: Center - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL($overscanadjust)}}
18:38:05 XMLConverter: CCmds_getParam: $overscanadjust,
18:38:05 ATVSettings: getsetting 0
18:38:05 XMLConverter: CCmds_applyConversion: 0
18:38:05 XMLConverter: XML_ExpandLine: 0 - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL($showendtime)}}
18:38:05 XMLConverter: CCmds_getParam: $showendtime,
18:38:05 XMLConverter: XML_ExpandLine: {{VAL($subtitlesize)}}
18:38:05 XMLConverter: CCmds_getParam: $subtitlesize,
18:38:05 XMLConverter: CCmds_getKey: 100,,False
18:38:05 XMLConverter: CCmds_applyConversion: 100
18:38:05 XMLConverter: XML_ExpandLine: 100 - done
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(ratingKey)}}
18:38:05 XMLConverter: XML_ExpandLine: {{VAL(Media/Part/duration)}}
18:38:05 XMLConverter: CCmds_getParam: Media/Part/duration,
18:38:05 XMLConverter: ====== generated aTV-XML ======
Gravity
Dr. Ryan Stone (Sandra Bullock) is een briljante medische ingenieur die op haar eerste shuttlemissie gaat met de ervaren astronaut Matt Kowalsky (George Clooney), die het commando heeft over zijn laatste vlucht voor hij met pensioen gaat. Maar een schijnbaar routine ruimtewandeling draait uit op een ramp. De shuttle wordt vernietigd waardoor Stone en Kowalsky alleen achterblijven – vastgeketend aan elkaar en steeds verder zwevend in het duister. De oorverdovende stilte verraadt dat ze elke link met de Aarde verloren hebben ... en elke kans op redding. Angst wordt paniek, en elke hap lucht vermindert de nog resterende hoeveelheid zuurstof. Maar misschien is de enige weg naar huis verder te gaan in de angstaanjagende uitgestrektheid van de ruimte.
218
True
24 Hour
Center
0
True
100
