Everything works except media playback
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): aTV 3  running 5.3(6105)
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.0.2
  • The device and operating system (including version number) that PlexConnect is installed on: iMac OSX Mountain Lion 10.8.4
  • The local IP address of the device that PlexConnect is installed on: 192.168.0.2
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: iMac OSX Mountain Lion 10.8.4
  • The Plex media server (PMS) version number you are running (**do not put 'latest'**): 0.9.7.28.33-f80a4a2
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.0.2
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. Tuesday, 9 July 2013 11:36 AM
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
  • [PlexConnect]
    port_pms = 32400
    enable_plexgdm = True
    ip_dnsmaster = 8.8.8.8
    ip_webserver = 0.0.0.0
    loglevel = Normal
    enable_dnsserver = True
    ip_pms = 192.168.178.10
    port_webserver = 80
  • Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space): Applies to all media files
  • detailed description of the issue (the clearer you can make this the better): Like the above details say that I downloaded the lastest GITHUB version of PlexConnect and have followed all the instructions to the dot (as to my understanding). I am able to view PLex on my aTV3. I can see movies and TV shows listed. I can see the movie info everything. But when i try to play a movie i get the error msg "An error occurred loading this content". from some other post that I have read I tried pressing the play/pause button on atv remote and the movie does not play.
  • Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one:
    • 02:52:57 WebServer: serving .xml: /library/sections
      02:52:57 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
      02:52:58 WebServer: serving .xml: /library/sections/2/recentlyAdded?stack=1&X-Plex-Container-Start=0&X-Plex-Container-Size=20
      02:52:59 WebServer: serving .xml: /library/sections/2/recentlyAdded?stack=1&X-Plex-Container-Start=0&X-Plex-Container-Size=20
      02:53:00 ATVLogger: loadURL (override): http://trailers.apple.com/library/sections/2
      02:53:00 WebServer: serving .xml: /library/sections/2
      02:53:00 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
      02:53:00 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/updateXML.js
      02:53:00 ATVLogger: 1
      02:53:02 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
      02:53:11 DNSServer: DNS request received!
      02:53:11 DNSServer: Source: ('192.168.0.19', 50318)
      02:53:11 DNSServer: Domain: trailers.apple.com
      02:53:11 DNSServer: ***intercept request
      02:53:11 DNSServer: -> DNS response: 192.168.0.2
      02:53:11 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/10292
      02:53:11 WebServer: serving .xml: /library/metadata/10292
      02:53:13 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
      02:53:13 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/selectAudioAndSubs.js
      02:53:14 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/10292
      02:53:14 WebServer: serving .xml: /library/metadata/10292
      02:53:16 ATVLogger: Player state: Loading at this time: 0
      02:53:16 ATVLogger: Player state: Stopped at this time: 0
      I am not sure what else to do any help would be appreciated.
      Cheers
Could you do two things please?:
  1. restart PlexConnect and capture the log file from startup
  2. give details of an example of one of the files you attempt to play
Hey f00b4r, i know this is a silly question, but i rather feel like an ass by asking it than not doing it properly. How do i restart plexconnect on mac properly. If you could give me the steps to follow… :slight_smile:
Pressing the exit button on the top or restarting your computer will turn it off. Then just reopen PlexConnect
  • Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space): http://pastebin.com/ayLEndRA
  • 14:40:44 PlexConnect: started: 14:40:44
    14:40:44 PlexConnect: ***
    14:40:44 PlexConnect: PlexConnect
    14:40:44 PlexConnect: Press CTRL-C to shut down.
    14:40:44 PlexConnect: IP_self: 192.168.0.2
    14:40:44 DNSServer: started: 14:40:44
    14:40:44 DNSServer: ***
    14:40:44 DNSServer: Starting up.
    14:40:44 DNSServer: intercept trailers.apple.com: 192.168.0.2
    14:40:44 DNSServer: forward other to higher level DNS: 8.8.8.8
    14:40:44 WebServer: started: 14:40:44
    14:40:44 WebServer: ***
    14:40:44 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
    14:40:44 PlexGDM: ***
    14:40:44 PlexGDM: looking up Plex Media Server
    14:40:45 PlexGDM: No servers discovered
    14:40:45 XMLConverter: PlexGDM - no PMS found
    14:42:32 DNSServer: DNS request received!
    14:42:32 DNSServer: Source: ('192.168.0.19', 58757)
    14:42:32 DNSServer: Domain: trailers.apple.com
    14:42:32 DNSServer: ***intercept request
    14:42:32 DNSServer: -> DNS response: 192.168.0.2
    14:42:32 WebServer: serving application.js
    14:42:32 WebServer: serving /Users/Baala/Movies/PlexConnect-XML_templates/assets/plexconnect.xml
    14:42:32 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:42:32 ATVLogger: loadItem: Library
    14:42:32 WebServer: serving .xml: /library/sections
    14:42:32 PlexGDM: ***
    14:42:32 PlexGDM: looking up Plex Media Server
    14:42:33 PlexGDM: servers discovered: 1
    14:42:33 XMLConverter: PlexGDM - PMS: 192.168.0.2:32400
    14:42:34 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:42:34 WebServer: serving .xml: /library/sections/1/recentlyAdded?stack=1&X-Plex-Container-Start=0&X-Plex-Container-Size=20
    14:42:39 ATVLogger: loadURL (override): http://trailers.apple.com/library/sections/1
    14:42:39 WebServer: serving .xml: /library/sections/1
    14:42:39 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:42:39 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/updateXML.js
    14:42:39 ATVLogger: 1
    14:42:40 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:42:40 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/updateXML.js
    14:42:40 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/settings.js
    14:44:29 DNSServer: DNS request received!
    14:44:29 DNSServer: Source: ('192.168.0.19', 61848)
    14:44:29 DNSServer: Domain: trailers.apple.com
    14:44:29 DNSServer: ***intercept request
    14:44:29 DNSServer: -> DNS response: 192.168.0.2
    14:44:29 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/11173
    14:44:29 WebServer: serving .xml: /library/metadata/11173
    14:44:29 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:44:29 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/selectAudioAndSubs.js
    14:49:55 DNSServer: DNS request received!
    14:49:55 DNSServer: Source: ('192.168.0.19', 60515)
    14:49:55 DNSServer: Domain: trailers.apple.com
    14:49:55 DNSServer: ***intercept request
    14:49:55 DNSServer: -> DNS response: 192.168.0.2
    14:49:55 ATVLogger: loadAndSwapURL (override): http://trailers.apple.com/library/metadata/11173
    14:49:55 WebServer: serving .xml: /library/metadata/11173
    14:49:55 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:49:55 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/selectAudioAndSubs.js
    14:50:32 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/11173
    14:50:32 WebServer: serving .xml: /library/metadata/11173
    14:50:32 ATVLogger: Player state: Loading at this time: 0
    14:50:37 ATVLogger: Player state: Stopped at this time: 0
    14:52:45 DNSServer: DNS request received!
    14:52:45 DNSServer: Source: ('192.168.0.19', 63580)
    14:52:45 DNSServer: Domain: trailers.apple.com
    14:52:45 DNSServer: ***intercept request
    14:52:45 DNSServer: -> DNS response: 192.168.0.2
    14:52:45 ATVLogger: loadAndSwapURL (override): http://trailers.apple.com/library/metadata/11173
    14:52:45 WebServer: serving .xml: /library/metadata/11173
    14:52:45 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:52:45 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/selectAudioAndSubs.js
    14:52:48 ATVLogger: loadAndSwapURL (override): http://trailers.apple.com/library/sections/1
    14:52:48 WebServer: serving .xml: /library/sections/1
    14:52:48 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:52:48 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/updateXML.js
    14:52:48 ATVLogger: 1
    14:52:49 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:52:49 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/updateXML.js
    14:52:49 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/settings.js
    14:52:52 ATVLogger: 0
    14:52:52 WebServer: serving .xml: /library/sections/1/all
    14:53:03 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:53:03 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/scrobble.js
    14:53:18 WebServer: serving .xml: /library/metadata/11320
    14:53:18 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/11320
    14:53:18 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
    14:53:18 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/selectAudioAndSubs.js
    14:53:21 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/11320
    14:53:21 WebServer: serving .xml: /library/metadata/11320
    14:53:21 ATVLogger: Player state: Loading at this time: 0
    14:53:22 ATVLogger: Player state: Stopped at this time: 0
Hey f00b4r, i know this is a silly question, but i rather feel like an ass by asking it than not doing it properly. How do i restart plexconnect on mac properly. If you could give me the steps to follow.. :)
Use CTR+c to shut it down cleanly.
If you just close the terminal window you may get issues restarting it without rebooting your machine.
Shut down PlexConnnect cleanly using CTR+c, then change the following line in settings.cfg, save it and restart PlexConnect:
ip_pms = 192.168.0.2
Hey, thank you that seemed to have worked, its taken me one more step ahead. So now it looks like it will play the movie/tv show but the seems to get stuck at loading the file.
Heres the log
7:43:01 WebServer: serving .xml: /library/sections/1
17:43:04 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:04 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/updateXML.js
17:43:04 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/settings.js
17:43:10 WebServer: serving .xml: /library/sections/2/recentlyAdded?stack=1&X-Plex-Container-Start=0&X-Plex-Container-Size=20
17:43:11 ATVLogger: loadURL (override): http://trailers.apple.com/library/sections/2
17:43:11 WebServer: serving .xml: /library/sections/2
17:43:11 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:11 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/updateXML.js
17:43:12 ATVLogger: 1
17:43:12 WebServer: serving .xml: /library/sections/2
17:43:13 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:15 ATVLogger: 0
17:43:16 WebServer: serving .xml: /library/sections/2/all
17:43:16 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:16 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/scrobble.js
17:43:18 ATVLogger: 2
17:43:18 WebServer: serving .xml: /library/sections/2/genre
17:43:19 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:19 ATVLogger: 3
17:43:19 WebServer: serving .xml: /library/sections/2
17:43:19 WebServer: serving .xml: /library/sections/2/genre/81?X-Plex-Container-Start=0&X-Plex-Container-Size=25
17:43:20 WebServer: serving .xml: /library/sections/2/unwatched?X-Plex-Container-Start=0&X-Plex-Container-Size=25
17:43:26 WebServer: serving .xml: /library/sections/2/recentlyViewedShows?X-Plex-Container-Start=0&X-Plex-Container-Size=25
17:43:29 WebServer: serving .xml: /library/sections/2/recentlyViewedShows
17:43:30 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:30 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/scrobble.js
17:43:34 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/9441/children
17:43:34 WebServer: serving .xml: /library/metadata/9441/children
17:43:35 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:35 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/scrobble.js
17:43:37 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/9444/children
17:43:38 WebServer: serving .xml: /library/metadata/9444/children
17:43:38 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:38 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/scrobble.js
17:43:40 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/9445
17:43:40 WebServer: serving .xml: /library/metadata/9445
17:43:40 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/utils.js
17:43:40 WebServer: serving  /Users/Baala/Movies/PlexConnect-XML_templates/assets/js/selectAudioAndSubs.js
17:43:42 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/9445
17:43:42 WebServer: serving .xml: /library/metadata/9445
17:43:42 ATVLogger: Player state: Loading at this time: 0
and now its 17:50:21 and the movie has not started playing..
the movies/tv shows are on an external hard drive attached directly to the imac, which is loacted in a different room and runs on WiFi, would this be one of the reason why the streaming has not started?
Hey, I figured what I had done, its all working now. Thank you for creating this app, I bought aTV3 in December hoping there would be a jailbreak and I would get to use XBMC. Thank you so much at last i get to watch my movies/TV shows the way I want to :)
What was the final piece of the puzzle?
I had turned the Force Transcoding option under settings on aTV to TRUE and i guess that was why it wasnt streaming the movie, also I had the Video rate at 1080p, 8mbps.. So i just went into the settings and turned that setting to FALSE and reduced the video rate to 720p. AFter that the streaming worked. Now I have updated the Video rate to 1080p, 40mbps and PERFECT streaming and superb quality.. I am watching BDRIP 8gb file and am enjoying it on my home theatre :)
I have the exact same issue as descibed by squidy_2000. The difference with me is that I don't have the Forece Transcoding option turned on and yet it gives me the same error in the log. When I check the log, each time I try to play a file this is logged:
22:18:46 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/12
22:18:46 WebServer: serving .xml: /library/metadata/12
22:18:46 ATVLogger: Player state: Loading at this time: 0
22:18:47 ATVLogger: Player state: Stopped at this time: 0
I tried turning the Force Transcoding option on and off but this didn't resolve the issue.
Please provide the info requested in the sticky and we will try and help.
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3, 5.3 (6105)
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.2.6
  • The device and operating system (including version number) that PlexConnect is installed on: MacBook Air OSX 10.8.4
  • The local IP address of the device that PlexConnect is installed on: 192.168.2.6
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: MacBook Air OSX 10.8.4
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.2.6
  • The PlexConnect version number. PlexConnect-0.1-iOS-pre5.1
[PlexConnect]
port_pms = 32400
loglevel = Normal
port_webserver = 80
  • Detail on the media file if it is an issue related to playing a media file : Goes for all media
  • Ensure you post your 'PlexConnect.log' file : https://dl.dropboxusercontent.com/u/12620437/PlexConnect.log
  • The error on the ATV states: An error had occured while loading this content, please try again later (translated from dutch to english :))
Can you do two things:
Update to the latest source code for PlexConnect.
If you still get the same issue generate a new smaller log (just restart PlexConnect, reproduce the issue and shut it down, so as not to generate thousands of lines :wink:
Thanks, I've updated my version to the latest version on github. I'm still having the same issue.
Should the log level be set to High as in the description? Because that's why my previous log was so huge. Here is the log with the reproduced issue and log level Normal.
I'm having similar issues using a qnap TS421 with the unofficial ARM package. Everything play's fine via the pc media center but on the ATV I get the same error as above. I'm holding off to post complete log's etc till I tried everything that will be available in this post. I don't want the hijack your tread :)
Frank
Yeah i think we will need the log level set to "High" (note the capital H). Just ensure you do the minimum number of steps to reproduce the issue, in order to keep the log level at a reasonable level.
Frank
Please post in the QNAP thread as that has the package creator and others with the same hardware responding in it.
Media not playing is a very very generic error and you are using something with another layer of complexity in it.
Oke, I switched the log level to High and this the result: http://pastebin.com/embed_js.php?i=PSHUGuyt
At the end you'll see this appearing twice:
  1. 13:02:46 WebServer: request options:
  2. {'PlexConnectLog': 'Player state: Stopped at this time: 0'}
  3. 13:02:46 ATVLogger: Player state: Stopped at this time: 0
