Movie info no longer updating
Server Version#: 1.21.1.3876
Player Version#: 4.47.3
Dear, everything was running smoothly for couple of years now when early December all new movies/tv shows has stopped downloading related info (posters, movie info, ratings, etc.) however when I do edit the movie manually I can select poster and background image however the matching info doesn’t show. Appreciate your help. I have been reading the online forums for the last 5 weeks but nothing helped. Here is the naming of one the latest movies I have “The Hunger Games: Mockingjay Part I.mp4”
I checked the matching and retrieval for this.
The naming I used:
[chuck@lizum movies.522]$ ls -la The\ Hunger\ Games:\ Mockingjay\ Part\ I/
total 12
drwxr-xr-x  2 chuck chuck 4096 Jan 15 10:19 ./
drwxr-xr-x 54 chuck chuck 4096 Jan 15 10:19 ../
-rw-r--r--  1 chuck chuck  318 Jan 15 10:19 The Hunger Games: Mockingjay Part I.mkv
[chuck@lizum movies.523]$
I notice you’re using MP4 files. Did you make certain the metadata / embedded tile in the file is either blank or correct? MP4 files can carry that info. If it’s incorrect, it will drive you crazy trying to find the problem. The easiest solution with MP4 files is to Edit the MP4 mediainfo and remove it all.
Thank you for your feedback, I have found the below metadata but nothing has to do with the movie info.
 mediainfo "The Hunger Games: Mockingjay Part I.mp4"
General
Complete name                            : The Hunger Games: Mockingjay Part I.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/avc1)
File size                                : 1.85 GiB
Duration                                 : 2 h 2 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 2 161 kb/s
Encoded date                             : UTC 2015-02-21 09:12:21
Tagged date                              : UTC 2015-02-21 09:12:21
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 2 063 kb/s
Maximum bit rate                         : 31.1 Mb/s
Width                                    : 1 920 pixels
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Original frame rate                      : 23.976 (23976/1000) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.056
Stream size                              : 1.77 GiB (95%)
Title                                    : video.264#trackID=1:fps=23.976 - Imported with GPAC 0.5.0-rev
Writing library                          : x264 core 142 r2479 dd79a61
Encoding settings                        : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=48 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2063 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2015-02-21 09:12:35
Color range                              : Limited
Color primaries                          : BT.709
Matrix coefficients                      : BT.709
Codec configuration box                  : avcC
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : mp4a-40-2
Bit rate mode                            : Variable
Bit rate                                 : 93.8 kb/s
Maximum bit rate                         : 104 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Compression mode                         : Lossy
Stream size                              : 82.4 MiB (4%)
Language                                 : English
Encoded date                             : UTC 2015-02-21 09:12:33
Look at the Title record.
Whoever ripped or encoded that, please forgive me, had no idea what they were doing. Clearly that’s not a title.
Get that info out of there. Make it blank.
When blank, PMS matches by file name.
I removed the metadata from file however issue still persist
General
Complete name                            : /home/patrick/Downloads/The Hunger Games: Mockingjay Part 1.mp4
Format                                   : MPEG-4
Codec ID                                 : isom (isom/iso2/avc1/mp41)
File size                                : 1.86 GiB
Overall bit rate                         : 2 163 kb/s
Writing application                      : Lavf58.29.100
Video
Format                                   : AVC
Codec ID                                 : avc1
Height                                   : 800 pixels
Color space                              : YUV
Bit depth                                : 8 bits
Audio
Format                                   : AAC LC
Bit rate mode                            : Constant
Default                                  : Yes
Alternate group                          : 1
