Movie Trailers
I like to have the ability to place a movie trailer file in the same folder as the full length file. Then have the option which to play. Much like if you have 2 versions of the same movie in the same folder. Thanks.
I think trailers should be streamed from youtube or somewhere like that… I don’t want to have to search and download a trailer for each movie anyway, it is to much work and should be automatically available through the correct metadata.
And this seems to be a duplicate of this post: http://forums.plexapp.com/index.php/topic/46189-popular-trailer-support/
duplicate, see -> http://forums.plexapp.com/index.php/topic/46189-popular-trailer-support/
Early 2021 clean-up: implemented
