Over the past month or so, whenever I have added a new TV show to plex I cannot download the metadata, a poster downloads for the show and that same poster is used for the seasons. Episodes are not named and there is no description in the shows page.
I have tried countless dances, reinstall, repairs, reverting to previous versions, clearing cache, disabling ipv6, resetting folder permissions, changing agent priorities and manually applying a match… and none of these have worked.
2018-05-21 00:05:49,197 (278) : DEBUG (networking:166) - Requesting 'https://tvdb2.plex.tv/login'
2018-05-21 00:06:03,211 (278) : INFO (logkit:16) - JWT Error: (<urlopen error [Errno 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond>) -
Something makes all requests to the TheTVDB metadata server fail.
if you run a 3rd party firewall/anti virus, tell it to not try and decrypt secure (TLS) communication packets. These attempts will cause the packets to get invalid.
don’t use ‘TCPoptimizer’ and similar software which manipulate the network stack parameters of Windows. If you did in the past, revert those changes to the defaults.
@Stertuos said:
Pinging tvdb2.plex.tv [52.187.49.10] with 32 bytes of data:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Then it is pretty clear that somehow your plex server (and probably your whole network!) cannot reach that server. There is nothing on the Plex Server side that can be done about it.
May I ask, where you are located?
Have you set up some kind of filter in your router (or maybe your ISP does it for you)?
If you query different DNS servers for the same domain name, they in theory should deliver all the same IP address back.
Anyway, I will alert the technical folks to verify proper status of the proxy in singapore.
Or did you set up a country-based filter somehere in your router or at your ISP?
I haven’t set up any country based filters in my router or ISP, I have used the VPN “vpn.ac” for a while but I feel as though I could get the tv show metadata since.
Is there any reason why trying to manual match a tv show even with TMDB fails to get the metadata?
