Movies incorrectly being merged
IDK if this is a problem with the latest DSM 7 install, but I redid my NAS after replacing the drives and I’m having issues with two movies so far, Kill Bill & Hunger Games Mockingjay. Each of them is is two parts in two separate movies correctly named:
Kill Bill Vol. 1 (2003).mkv
Kill Bill Vol. 2 (2004).mkv
The Hunger Games Mockingjay - Part 1 (2014).mkv
The Hunger Games Mockingjay - Part 2 (2015).mkv
What Plex is doing is for them is tagging the second ones as another version of the first one and I can’t find a way to split them. Any ideas? I’ve never seen this happen before…
The option to split should be in the context menu of the respective items ( > Split Apart)
Do you have each of those movies in their own folder? e.g.
Movies  <- the folder linked to your movie library
If you’re having issues despite organizing your files like this you can try to include an external reference to the movie’s folder (or the file itself), e.g.
  The Hunger Games Mockingjay - Part 1 (2014) {imdb-tt1951265}
  The Hunger Games Mockingjay - Part 2 (2015) {tmdb-131634}
Thanks for the menu info, I was just now able to fix Hunger Games. I split it and then fixed the match for the the second one and now it shows up correctly. I don’t use folders and never had to in the past, it’s only happened this time on a clean install of DSM 7 Plex v 1.24.1.4931
