Movies not updating
Server Version#: 1.15.4.994
Plex Media Scanner.1.log (11.0 KB)
My movies stopped updating about 3 days ago. Around that time I did an update and thought it might have something to do with the update so I performed a rollback and still won’t update.
I am guessing it has something to do with this.
Jun 07, 2019 17:13:30.799 [3576] ERROR - SQLITE3:0xba98e6b7, 11, database corruption at line 85694 of [bf8c1b2b7a]
Jun 07, 2019 17:13:30.799 [3576] ERROR - SQLITE3:0xba98e6b7, 11, statement aborts at 11: [SELECT idx, start_block, leaves_end_block, end_block, root FROM ‘main’.‘fts4_metadata_titles_segdir’ WHERE level = ? ORDER BY idx ASC] database disk image is malformed
Jun 07, 2019 17:13:30.799 [3576] ERROR - SQLITE3:0xba98e6b7, 11, statement aborts at 174: [update metadata_items set guid=?,hash=? where id=?] database disk image is malformed
Jun 07, 2019 17:13:30.799 [3576] ERROR - Exception inside transaction (inside=1) (…\Library\MetadataItem.cpp:1003): sqlite3_statement_backend::loadOne: database disk image is malformed
Jun 07, 2019 17:13:30.799 [3576] ERROR - Exception inside transaction (inside=1) (…\Library\MetadataItem.cpp:3424): sqlite3_statement_backend::loadOne: database disk image is malformed
not sure how to fix it.
You can try to repair the database but that does not always work
https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
or restore a database back up
https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
I couldn’t get the repair to work, but the back up helped.
Much obliged.
