Movies scraped with CineBlog01HD as name
Hi. It’s been a few months that some movies are matched, by plex, correctly aginst imdb, but when they appear in Plex Library, they have “CineBlog01HD” as their name. Tried rematching, but it comes with the same name everytime. The only way to fix it, is to change their name by hand. Anyone experienced this problem?
Very sure this has to do with embedded metadata in your files.
Do this:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
Afterwards, Refresh Metadata on the affected movies.
Maybe you are right… that CineBlog seems to be a site with media. I’ll try your suggestion and check if it happens again.
You were right :slight_smile:
