I’ve just done the guide here Moving PMS 'Library' - #2 by ChuckPa, verification steps worked as expected, but now that I’m at step H, the server is now offline and won’t come back online. I’m able to browse to other servers (friends ones)
Unsure where to go from here without undoing the changes
Service status:
● amahi-plex.service - Plex Media Server for Amahi
Loaded: loaded (/usr/lib/systemd/system/amahi-plex.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2019-03-31 22:24:16 BST; 6min ago
Process: 31446 ExecStopPost=/bin/rm -f /run/amahi-plex.pid (code=exited, status=0/SUCCESS)
Process: 31377 ExecStop=/usr/bin/kill $MAINPID (code=exited, status=0/SUCCESS)
Process: 31448 ExecStart=/usr/bin/amahi-plex (code=exited, status=0/SUCCESS)
Main PID: 31450 (runuser)
Tasks: 77 (limit: 4915)
CGroup: /system.slice/amahi-plex.service
├─31450 runuser -u apache -g users /usr/lib64/plexmediaserver/Plex Media Server
├─31451 /usr/lib64/plexmediaserver/Plex Media Server
├─31463 Plex Plug-in [com.plexapp.system] /usr/lib64/plexmediaserver/Resources/Plug-ins-782228f99/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.15.2.793-782228f99 /usr/lib64/plexmediaserver/Resources/Plug-ins-782228f99
├─31505 /usr/lib64/plexmediaserver/Plex DLNA Server
├─31507 /usr/lib64/plexmediaserver/Plex Tuner Service /usr/lib64/plexmediaserver/Resources/Tuner/Private /usr/lib64/plexmediaserver/Resources/Tuner/Shared 1.15.2.793-782228f99 32600 /waitmutex
└─31552 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib64/plexmediaserver/Resources/Plug-ins-782228f99/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.15.2.793-782228f99 /usr/lib64/plexmediaserver/Resources/Plug-ins-7822Mar 31 22:24:16 localhost.localdomain systemd[1]: Starting Plex Media Server for Amahi…
Mar 31 22:24:16 localhost.localdomain systemd[1]: Started Plex Media Server for Amahi.
Mar 31 22:24:16 localhost.localdomain runuser[31450]: pam_unix(runuser:session): session opened for user apache by (uid=0)
I noted that I needed to do mount /home/plexdata/Library instead of mount /home/plexdata but other than that, no errors showed
