Hello,
To gain some space on my NAS I would like to move some of my movies to another “folder”. This folder is in fact a shared folder on another NAS which is connected to the first NAS via CIFS distant connection.
In Plex, my movie library is configured to look at the original folder and the new one. Everything works fine (except everything is doubled for now, I’ve not empty the original folder intentionaly).
The problem is with metadata : each movie I’ve personalized (name, cover, …) is getting back to their original state (the one in the new folder, the original is fine).
Is there a way to say to metadata “hey, all the movie library has moved here, update yourself please!”
When you add a second (which will be a duplicate) folder location,
-AND-
Copy the same media there,
When PMS is done scanning that new folder,
Examining the “Get Info” for each item will show you it has two paths.
This is how you confirm PMS has two locations, with same metadata, for the same item.
Now, as you want, you can safely remove the first folder reference from the list.
PMS will update again and remove it.
It will still keep the 2nd (which now becomes the master) location.
I’m not sure to understand what you’re saying because Plex doesn’t seem to find that movies are the same.
I can guarantee that “movie” folder is an exact copy.
It seems that for “2 Guns” it finds all the info by itself but not for “4x4”. As you can imagine, the good 4x4 is in my old folder and the bad one is the fresh copy.
I’m quite scared of “delete” the old folder in the library configuration because if I lost all my metadata it would be a lot of job…
EDIT :
I’ve force a re-scan and a metadata refresh and I’ve partially what you were saying. But I’m not sure it’s a good result as some of the movies are always “duplicate”
Thank for the article linked.
I already have problems because it PARTIALLY works. Some of movies (the majority) are listed as duplicate like 2 Guns.
But some (about 40-50) are “real” duplicate like “4x4” and “4x4 2019” which is the same file in the 2 folders…
I’ll try to delete the old folder in library configuration and we will see ^^ For 50 films I could do it manually
