I’d like to Move just my Data (Media art + meta data) => volume 3
Media is on volume 2
Leaving the Flex Binaries in place => volume 1
G
I am writing this post.
- The installer will let you put the binaries (all 200 MB of them) where you select. You select the location in Package Center. DSM actually puts the binaries in
@appstoreon the selected volume. - If you move the Plex share, You only need move the share when the package isn’t installed. Upon re-installation, the installer finds it.
Think you misunderstanding my question.
ok so I told DSM to install all packages to volume1 (M.2 based), so as you say this will then be to the @appstore, and I’d like to leave the binaries here, I only want to move my PLEX meta data location, the media art etc.
PLex seems to cater for this easily on the Windows environment, by giving you the option under Settings/server/Advance, but not for Linux based hosts.
G
- The Plex binaries are under control of DSM and get placed in
@appstoreon the same volume as thePlexshare (your metadata) by default. - If you select to install Plex on
volume2, DSM will put the binaries there also. This is beyond my control (I wrote the installer). - If you only wish to move the
Plexshare (your metadata) to a different volume, the task is easier.
Do the following as a username with administrative privilege:
- Uninstall the app
- Rename
Plexshare name tooldPlexor other name convenient name in Control Panel - Shared folders - Create new share, named
Plexon the desired volume - Using File Station, move the metadata (
Library) and temporary transcoding directories to the newPlexshare - After move complete, right-click
Library- Properties. Verify it is still owned by userplex. If not, make it so and apply tothis folder, sub folders and files. - Remove the
oldPlexshare - Install the app.
- As it installs, the installer looks to see if you have an existing
Plexshare. If so, it attaches the package to it. If it finds none, then it creates a new share. - If, during installation, the new volume starts ‘rattling’ hard, it is because the installer found something in the metadata not owned by user
plex. When I detect this, I make it forcibly set the ownership of everything in thePlexshare toplex:users.
Windows cating is irrelevant. QNAP allows migration. Synology does not provide such a mechanism . I must abide by the Synology package SDK.
I wish to share here because it makes sense to and someone, sometime in the future, reads this.
The Plex share is intended for metadata only. It is stored on a volume because the default OS area is too small. Out on the volume, as a share, is the only way I could do it and give everyone a means some level of control over it. It’s also the only way one can get the log files in the event PMS doesn’t start without resorting to using the shell / command line.
Thanks, will go looking/digging/playing around on my lab environment.
G
