Moving the vertical list of "skip-to" letters first (instead of 7th) when viewing a library
When viewing the list of movies or shows in my library, I have to navigate past all titles in the topmost row before getting to the righthand side navigation where the vertical alphabet-list lets me to move rapidly between titles (by name). I’d like to have the ability to put the vertical list of letters on the left-hand side of the list so I can get to it with one click instead of having to always move across the top to the letter-navigation bar.
When navigating the leftmost column menu, I select “Movies”, changing the right pane to show my movies from Numbered shows through ‘Z’. Then I have to ‘walk’ right, across the top line of shows before I can get to the navigation for the letter selections. Only then can I indicate I want a show starting with ‘S’ (or whatever). It makes sense to put the navigation together, along the left-side of the web page/device page (Roku/Chromecast) instead of having it broken across the shows.
It would make it faster/easier/less-confusing to put the navigation controls together – the vertical navigation column (Home, Watchlist, TV Shows, Movies, etc…) on the left hand side should only require 1-click to the right to get to the letter-selection for fast repositioning within the center column of titles instead of making me navigate past each of the titles in the top row before being able to specify that I want a show much farther down.
There’s already a similar suggestion asking for an option to access the alphabet index from the library’s action bar (top) in order to improve usability / reduce the number of clicks required to access the index.
