MP4 audio files suddenly will not play
Server Version#: 1.40.3.8555-6000
Player Version#: Amazon Firestick (is that what you are looking for?)
Several months ago I uploaded some mp4 audio files from a few medical summits that I attended and bought. They worked just fine. Now when I have gone back to listen on the Firestick, I get the following error message.
! Error
An error occurred while attempting to play this video. Please check your connection and try again.
When I open Plex on my desktop and click to play the audio, it plays fine. So it must be an Firestick issue.
Can someone provide some input as to what could be wrong now? It must have occurred from one of the server updates that we have to download and install all too often these days. IDK
Thank you
Can you please do the following?
  1. Settings - Server - General - Show Advanced
  2. make certain DEBUG logging on & VERBOSE logging off (SAVE if changed)
  3. Now recreate the error please
  4. Settings - Server - Troubleshooting - Download Logs
It will give you a ZIP file. Please attach it here
I followed your steps and here is the zip file.
Plex Media Server Logs_2024-06-17_13-35-35.zip (4.4 MB)
Thanks for the logs.
What I see is Android starting to play then aborting from the player side.
Have you tried playing the MP4 files in the browser ?
Jun 17, 2024 11:44:25.726 [547400462560] DEBUG - [Req#6102/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-limitation(scope=videoCodec&scopeName=h264&type=upperBound&name=video.level&value=52)+add-limitation(scope=videoCodec&scopeName=*&type=upperBound&name=video.width&value=3840&replace=true)+add-limitation(scope=videoCodec&scopeName=*&type=upperBound&name=video.height&value=2160&replace=true)+add-limitation(scope=videoCodec&scopeName=hevc&type=notMatch&name=video.DOVIProfile&value=5)+add-transcode-target(type=videoProfile&context=streaming&protocol=hls&container=mkv&videoCodec=h264,hevc,mpeg2video&audioCodec=aac_latm,aac,aac,ac3,alac,dca,eac3,flac,mp1,mp2,mp3,opus,vorbis,wmav1,wmav2,wmalossless,wmapro,wmavoice&subtitleCodec=ass,pgs,subrip,dvd_subtitle,mov_text,vtt,dvb_subtitle&replace=true)+add-transcode-target-settings(type=videoProfile&context=streaming&protocol=hls&CopyMatroskaAttachments=true)+add-limitation(scope=videoAudioCodec&scopeName=aac&type=upperBound&name=audio.channels&value=8&replace=true)+add-transcode-target-audio-codec(type=videoProfile&context=streaming&protocol=hls&audioCodec=mp3)+add-transcode-target-audio-codec(type=videoProfile&context=streaming&protocol=hls&audioCodec=ac3)+add-transcode-target-audio-codec(type=videoProfile&context=streaming&protocol=hls&audioCodec=eac3)+add-transcode-target-audio-codec(type=videoProfile&context=streaming&protocol=hls&audioCodec=dca)+add-transcode-target-audio-codec(type=videoProfile&context=streaming&protocol=hls&audioCodec=opus)+add-limitation(scope=videoCodec&scopeName=*&type=NotMatch&name=video.anamorphic&value=999&replace=true)+add-transcode-target(type=subtitleProfile&context=streaming&protocol=http&container=mkv&subtitleCodec=srt)+append-transcode-target-codec(type=videoProfile&context=streaming&protocol=hls&videoCodec=mpeg2video)+append-transcode-target-codec(type=videoProfile&context=streaming&protocol=hls&videoCodec=hevc)+add-limitation(scope=videoCodec&scopeName=hevc&type=Match&name=video.profile&list=main|main 10)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=match&name=video.colorTrc&list=smpte240m|smpte170m|bt470m|bt470bg|bt2020-10|bt709&isRequired=false)
Jun 17, 2024 11:44:25.727 [547400462560] DEBUG - [Req#6102/Transcode] TranscodeUniversalRequest: using augmented profile Android
Jun 17, 2024 11:44:25.727 [547400462560] DEBUG - [Req#6102/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/1852?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=f78afa7167862fbe-com-plexapp-android
Jun 17, 2024 11:44:25.738 [547400462560] DEBUG - [Req#6102/Transcode] Streaming Resource: Reached Decision id=1852 codes=(MDE=1000,Direct play OK.) media=(id=2283 part=(id=2367 decision=direct play protocol=* streams=(Audio=(id=5064 decision= channels=0 rate=0))))
Jun 17, 2024 11:44:25.739 [547459645664] DEBUG - Completed: [192.168.0.3:57638] 200 GET /video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F1852&protocol=*&session=f78afa7167862fbe-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (11 live) #6102 TLS GZIP 14ms 1262 bytes (pipelined: 10)
Jun 17, 2024 11:44:28.254 [547461755104] DEBUG - handleStreamRead code 1: stream truncated
Jun 17, 2024 11:44:28.254 [547461755104] DEBUG - NotificationStream: Removing because of error
Jun 17, 2024 11:44:28.254 [547461755104] DEBUG - Completed after connection close: [192.168.0.3:57642] -3 GET /:/websockets/notifications (11 live) #5e39 TLS GZIP 31419ms 143 bytes
Jun 17, 2024 11:44:28.255 [547459645664] DEBUG - handleStreamRead code 1: stream truncated
Jun 17, 2024 11:44:28.255 [547459645664] DEBUG - NotificationStream: Removing because of error
Jun 17, 2024 11:44:28.255 [547459645664] DEBUG - Completed after connection close: [192.168.0.3:57546] -3 GET /:/websockets/notifications (10 live) #5b22 TLS GZIP 314143ms 227 bytes
Yes, the files will play in the browser. They will not play in the Android app, Firestick. But they used to play in the Android app. So I am wondering why do they not play now?
@StormyClouds
I have sent you a PM.
I don’t see any PM from you. Just a message from Discobot.
