For issues Not Directly Relating to this beta but rather issues relating to PMS in general, Please create a separate thread.
Finding and sorting the individual issues here is not possible.
Thanks.
Thanks.
Ciao Chuck!
News?
Hello everyone
I find that this version greatly accelerates the opening of the application via my Sony TV and my playstation 4 and that its overall responsiveness and access to files on the server Synology 218play have improved
Yours,
LeDime
Iām back from holidays. This means Iām available for tests concerning the DS118 and the crashes which occurred on my model.
Iāve been waiting to install this build on my Synology until the next (smaller) build is out⦠Excited to see how the next one performs!
Do you have some news ?
Engineering is out this week at a conference.
Hope to have more info when they return
I would like to test 1.13.7 on my Synology DS716+, but in case if something, I want to have a possibility to rollback. Is it possible to get an older package?
Hello
Iām on a QNAP 932X and have managed to install the ARMv8 package, but config page on 32400 does not load. Plex Pass user. Any ideas? And super thanks for this project guys!!!
Your NAS has a Alpine AL-324 quad-core CPU. I donāt know if the ArmV8 package is designed for that CPU. You might have better luck with the ArmV7 version designed for the AL-314.
Are you using IPv6? There is a known issue with IPv6 blocking access to port 32400 (not allowing binding).
The log files should be extracted and examined.
The easiest way to access the logs is via a shared folder. Dane22 was kind enough to write this package which creates a PMS share for this purpose. (create a ZIP of the Logs directory from within File Station).
Link to my G-drive: PMSLibShare_1.0.qpkg
https://drive.google.com/open?id=1RwUzutmZ--Yvdpp6ZkhpPiBK-xFqBF1l
It appears to be an issue with the latest build PlexMediaServer-1.13.6.283-9e747cb50-aarch64.qpkg
I have been able to run PlexMediaServer-1.13.6.176-dd1845234-aarch64.qpkg without issues. Thank you. Will stay tuned for updates.
Is there a new version for the DS118 to try? I as previously stated Iām now able to do tests and have physical access to it.
The engineering team has been away for the past week.
I will learn more when they return Monday.
Itās Tuesday
Itās realy long⦠do you have somes news ā¦
I just looked in on current activities there.
They found a few issues and are fixing them.
I will not interrupt at this point as the dialog is pretty hot & heavy.
Also, they were all out last 10 days for a conference.
Thanks for the update, Chuck! Looking forward to a new build.
Thanks Chuck ! Iāll try to be patient⦠but itās so hard
I know it is. Worse than being 6 years old and seeing a stack of gifts in the corner but knowing you canāt open them yet.
