Mulitple Issues Xbox One
Hi Plex,
Constant issues with the xbox one.
1. Will randomly skip forward about 45secs to 1 minute. You rewind and it plays fine for a while then may do it again.
2. Just stops working. Goes to a screen that says server error. Go home or retry are the options. Press retry and it resumes from a few seconds before it stopped. Until it does it again.
3. Video starts playing from the end. Even though it is unwatched or has been watched to the end already. Doesn't always present an option to play from beginning.
4. Sometimes you are watching something and the stream will glitch and show you a say 10-15 seconds of footage from something else you have watched. It will then resume your film 10-15 seconds after the place it started skipping.
My LAN is gigabit and the server is an i7 4series with 32gb of ram and an SSD. So there is no way the server cant keep up the data stream.
If anyone needs logs then let me know what to send.
I am a lifetime subscriber.
Lol snap - virtually same as my thread i just started :)
Although 4 sounds bloody bizarre!
Apparently they are aware of #1 and #3.. #2 ive only ever seen when there is a network issue like, dropped packets..
For what it’s worth, I get 2 sometimes if I leave it paused for a while, usually longer than 5 minutes. Or if I leave Plex for another app, say Netflix, when I eventually come back I’ll get that screen as well. Also, on gigabit, hard wired, with a recent i7 based system.
