Since the October update, I have had several serious issues that effectively mean I can no longer use the XBOX One app.
Cannot scrub through media, always returns to original timecode.
Media stops playing at random times with the message “An unexpected error occurred while decoding the media.” Attempting to resume playback results in media playing from the start. The same media could play without issue on the old app and in web browser.
Server is headless ubuntu with 12TB raid , connected to xbox one via gigabit ethernet through cisco switch.
Happy to provide logs if it would help. Any ideas?
@“adferro@gmail.com” Thanks for the logs. It’s a bit tricky to pin down where the issue actually happens. Could you tell me which item was playing or the rough timestamp?
Hi, to make it easier I’ve attached new logs, as the issue just happened again and I’ve noted the time.
I was watching American Horror Story S07E06 and it stopped at 15:06 timestamp. The real time was about 7:48PM, give or take a couple of minutes. I’ve also attached the info of the particular file (bitrate, size, format, etc.) in case it’s useful.
Same issues, and it happens with A LOT of media. If you stop, pause, fast forward, anything to cause play back to stop, it starts at the beginning. No way to get back to where it was.
Server: Plex Media Server v1.9.6.4385-ef7796e43 - Microsoft PC x64 - build: windows-i386 english - GMT -05:00
Error:
DEBUG - handleStreamRead code 10054: An existing connection was forcibly closed by the remote host
DEBUG - Failed to stream media, client probably disconnected: 10054 - An existing connection was forcibly closed by the remote host
Not sure if they changed something but I literally just got through my first tv episode with 0 skips or issues. I’m going to move onto another tv show and see if improved. If theres no followup message from me in this thread assume it’s good news.
I am also having this problem with movies on my Xbox One. Anytime I play a movie, I have no problems until you hit the 75% watched mark. At this point it says that there was an issue decoding the movie, and that it will not continue. This seems to correspond with receiving the Xbox update. This will happen regards of movie.
